[geos-devel] Buffer op - end cap styles
Mateusz Loskot mateusz at loskot.net
Thu Feb 1 20:42:51 EST 2007
Ben Supnik wrote:
> Also, how can I compile a debug build of GEOS?  Are there flags in the
> configure file for this?  I'd like to be able to break within the lib in
> gdb.  (I am compiling on Mac OS X using the std unix configure file.)
-g option is turned on by default.
Next, to disable NDEBUG macro use --enable-cassert:
./configure --enable-cassert=yes
Cheers
Mateusz Loskot
http://mateusz.loskot.net
