[geos-devel] nasty ring bug
Carl Anderson carl.anderson at vadose.org
Tue Feb 20 23:17:34 EST 2007
I forgot to post my working example of the "Nasty Buffer" bug
The commonality between the two examples are:
Multipolyon
    first ring is
       single closed ring with no holes
    second or later ring is
       contains the first ring in the Y dimension but has no overlap in
the X dimension
       has a hole that overlaps the first ring in the Y dimension but
has no overlap in the X dimension
I have not been able to manually construct a new nasty bug with these
rules, so there is at least one additional rule
I don't see just yet.
I am currently digging in BufferOp.cpp around the routine find
StabbedSegments()
C.
Type: text/xml
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20070220/17a088a6/hole_red.xml
