[geos-devel] New problem when compiling QGis against geos 3.0.0rc4
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Thu Feb 22 03:27:21 EST 2007
On Wed, 2007-02-21 at 09:54 +0100, strk at refractions.net wrote:
> Mark, can you confirm the below patch works for you ?
> It works here, but this mine is *not* a MINGW32 system.
> --strk;
I've just done a quick test on my MingW cross-compile environment and
GEOS still compiles, so I'd say commit the change. I guess I didn't
understand the inlines code as well as I thought - thanks Mike/Tom for
the fix.
Kind regards,
Mark.
