[geos-devel] Another RC?
strk at refractions.net strk at refractions.net
Thu Jan 4 18:06:14 EST 2007
On Thu, Jan 04, 2007 at 03:46:34PM -0700, Charlie Savage wrote:
> Hey Strk,
> What do you mean regenerate geos.i?  What part changes?
I just mean that it will be generated running ./configure.
This is only to substitute version strings (they were shipped as rc1 in rc3).
BTW, another problem is failing 'make check':
swig/python/Makefile.am:16: `pkgpyexec_LTLIBRARIES' is used but `pkgpyexecdir' is undefined
swig/python/Makefile.am:16: The usual way to define `pkgpyexecdir' is to add `AM_PATH_PYTHON'
swig/python/Makefile.am:16: to `configure.in' and run `aclocal' and `autoconf' again.
swig/python/Makefile.am:15: `pkgpython_PYTHON' is used but `pkgpythondir' is undefined
swig/python/Makefile.am:15: The usual way to define `pkgpythondir' is to add `AM_PATH_PYTHON'
swig/python/Makefile.am:15: to `configure.in' and run `aclocal' and `autoconf' again.
swig/python/Makefile.am:14: `python_DATA' is used but `pythondir' is undefined
swig/python/Makefile.am:14: The usual way to define `pythondir' is to add `AM_PATH_PYTHON'
swig/python/Makefile.am:14: to `configure.in' and run `aclocal' and `autoconf' again.
swig/python/Makefile.am:24: variable `_geos_la_LIBADD' is defined but no program or
swig/python/Makefile.am:24: library has `_geos_la' as canonic name (possible typo)
swig/python/Makefile.am:23: variable `_geos_la_LDFLAGS' is defined but no program or
swig/python/Makefile.am:23: library has `_geos_la' as canonic name (possible typo)
swig/python/Makefile.am:18: variable `_geos_la_SOURCES' is defined but no program or
swig/python/Makefile.am:18: library has `_geos_la' as canonic name (possible typo)
--strk;
