[geos-devel] Building GDAL with GEOS in Unix
Mateusz Loskot mateusz at loskot.net
Thu Jan 4 18:24:05 EST 2007
Elavazhagan.M wrote:
> “./configure –with-geos=yes”. This did not work so I tried with
> “./configure  --with-geos=/root/usr/bin/geos-config” also.
Could you check if in the summary output from the ./configure
includes GEOS support marked with yes?
> Do I need to change anything in the makefiles of GDAL?
No, you should not need to change anything there.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
