[geos-devel] Re: AW: [GEOS] missing geos_c.h.vc
Mateusz Loskot mateusz at loskot.net
Fri Jun 8 10:54:37 EDT 2007
Baumann, Konstantin wrote:
> I know, how I can fix this by hand, but I would like to have it
> automatically done, since I would like to add GEOS as an external SVN
> reference in our SVN project tree and therefore I need it to be
> checkout-able and compilable without manual work done in between...
> Can't you reference the "version.h" from headers/geos/version.h from
> within geos_c.h(.in)? Then you do not need to duplicate the
> versioning information...
Hi Konstantin,
I tested and applied your suggestion to the SVN,
so now the problem with generating geos_c.h.in for VC++ seems to be
solved. Thanks!
> About the warnings: if you plan to fix them, leave the warnings on...
Yes, I'm cleaning them day by day.
p.s. I'm pushing my reply to the GEOS list so we have archived
information about source of this patch above.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
