[geos-devel] Binary Predicate Bug - Even Worse!
Paul Ramsey pramsey at refractions.net
Tue Jun 12 11:42:14 EDT 2007
The OGC SFSQL document says that
A.Within(B) implies Insersection(A,B) == A
And Contains is just defined for commutative purposes against Within():
A.Within(B) implies B.Contains(A).
So, you might not like the semantics, but they are implemented as
defined by the standards body.
Paul
Todd Jellett wrote:
> It turns out that this is also the case for identical geometries!
> If you take just GeomA and run all the listed binary predicates (below)
> against itself, you get exactly the same as below.
> Running GeomA->GeomA I get:
> Disjoint    False
> Equal       True
> Touch      False
> Contain    True
> Within      True
> Overlap    False
> Running a simple geometry against itself should return True for Equals
> *only*. It is ambiguous to be also contained and within.
> Todd
   Paul Ramsey
   Refractions Research
   http://www.refractions.net
   Phone: 250-383-3022
   Cell: 250-885-0632
