[geos-devel] supporting filters
Kralidis,Tom [Burlington] Tom.Kralidis at ec.gc.ca
Sun May 27 17:23:24 EDT 2007
> > Tom,
> > I'm also interested in some info about internals of DWithin
> and Beyond
> > operations.
> > These both operations are supported by FDO
> > (http://fdo.osgeo.org) but unfortunately I've not found much
> > information about their specification.
> True.  The only info I found was from FES 1.0.0, section 8.2:
> "The spatial operators DWithin and Beyond test whether the value of a
> geometric property is within or beyond a specified distance of the
> specified literal geometric value."
> So both DWithin and Beyond take as inputs a geometry and
> distance value.
> > I also need to learn about it soon, so if I will find
> > anything I let you know.
Further info from Peter Vretanos (FES 1.0.0 spec editor):
"According to the BNF in the Cat 1.0 specification DWithin tests to see
whether geometry A is completely within a certain distance of geometry
B.
I interpret this to mean a "buffer" query.  That is you create a buffer
around A at the specified distance and then do a WITHIN (as defined in
SFSQL) between this new buffer-expanded geometry (A') and the test
geometry B.  If B is completely within A' then the operator evaluates to
true
BEYOND is the opposite of DWITHIN.   If B is completely outside of A'
then the operator evaluates to true."
Cheers
..Tom
