[geos-devel] OSX 10.5 compile problem
Mateusz Loskot mateusz at loskot.net
Thu Nov 22 22:08:06 EST 2007
William Kyngesburye wrote:
> When compiling on OSX 10.5, I get an error in HCoordinate.cpp:
> HCoordinate.cpp: In member function 'long double
> geos::algorithm::HCoordinate::getX() const':
> HCoordinate.cpp:197: error: 'finite' was not declared in this scope
> If I use the 10.4u SDK it compiles (as it does in OSX 10.4).  Something
> must have changed in <cmath>, but it's beyond me.
William,
Sorry for the long delay.
I reported this problem to our brand new Trac along with proposing solution:
http://trac.osgeo.org/geos/ticket/162
I didn't applied this fix to SVN as I'd like to ask you for test.
I don't have Leo installed yet.
Could you replace the line 197 with new line proposed in the ticket,
and see if it compiles for you?
> PS.  Is there something wrong with the bug tracker?
We've migrated to OSGeo Trac:
You can use the same credentials that you use for GDAL and other OSGeo
projects.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
