[geos-devel] no outgoing dirEdge found error
Stuart C Sides ssides at usgs.gov
Tue Sep 18 22:37:47 EDT 2007
Hi GEOS devels,
We are writing a C++ application which is looking for areas of overlap
between 1000's  of polygons. The app is being
developed on Linux with g++ 4.1.0.
We first tried the stable release of GEOS 2.2.3 and received this error
after processing several polygons:
    TopologyException: found non-noded intersection between 87.9595
-40.3145, 87.9484 -40.2598 and 87.9857 -40.3126, 87.9575 -40.3146 87.9595
-40.3145
While reviewing the list archives we found references to major code
changes that might fix some of these errors, so we
upgraded to RC3 and eventually to an SVN version from 2007-09-18. We got
through a lot more polygons without errors,
but finally received this error:
    TopologyException: no outgoing dirEdge found 87.957 -40.1615
Note: this coordinate is from the first segment of the second polygon of
the first multi-polygon below.
In the original code, before I converted the multipolygons to strings to
create the example, we received this error:
    TopologyException: no outgoing dirEdge found 87.7184 -40.3315
multi-polygon below:
I've boiled the error down to just a few lines of code, and would
appreciate any suggestions.  The error is thrown at the
difference.
Thanks
Stuart
#include <string>
#include <iostream>
#include <geos/geom/PrecisionModel.h>
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/Geometry.h>
#include <geos/geom/MultiPolygon.h>
#include <geos/io/WKTReader.h>
int main (int argc, char *argv[])
  std::string mp1s = "MULTIPOLYGON (((88.0541300495810049
-40.3914336120775417,"
    " 88.0013586636740683 -40.3952580652168507,"
    " 87.9856522556763849 -40.3125682141688557,"
    " 88.0410955427405639 -40.3084853410231361,"
    " 88.0447770149226727 -40.3320733430391556,"
    " 88.0541300495810049 -40.3914336120775417)),"
    " ((87.9569549228361041 -40.1614847724049824,"
    " 87.9594803530699494 -40.3144955269957563,"
    " 87.9484023890450430 -40.2597855714132962,"
    " 87.9236385364479673 -40.1638760511710515,"
    " 87.9569549228361041 -40.1614847724049824)))";
  std::string mp2s = "MULTIPOLYGON (((87.7184147523609425
-40.3314878875577705,"
    " 87.7106409229361930 -40.2916861830969211,"
    " 87.6363928113999862 -39.9074815079801084,"
    " 87.8588765594887349 -39.8933226300382628,"
    " 88.3245648150878964 -39.8616404104367064,"
    " 88.3252910982550503 -39.8653834273614933,"
    " 88.4058355104796334 -40.2774282017416283,"
    " 88.4066631207306273 -40.2815647501607259,"
    " 87.9574816223991007 -40.3146427145853394,"
    " 87.7184147523609425 -40.3314878875577705)))";
  try {
    geos::geom::PrecisionModel *model =
        new
geos::geom::PrecisionModel(geos::geom::PrecisionModel::FLOATING);
    geos::geom::GeometryFactory *factory = new
geos::geom::GeometryFactory(model);
    geos::io::WKTReader *wkt = new geos::io::WKTReader();
    geos::geom::MultiPolygon *mp1 = (geos::geom::MultiPolygon
*)wkt->read(mp1s);
    geos::geom::MultiPolygon *mp2 = (geos::geom::MultiPolygon
*)wkt->read(mp2s);
    std::cout << "Is valid of one = " << mp1->isValid() << std::endl;
    std::cout << "Is valid of two = " << mp2->isValid() << std::endl;
    geos::geom::Geometry *diff = mp1->difference(mp2);
    std::cout << mp1->toString() << std::endl;
    std::cout << mp2->toString() << std::endl;
    std::cout << diff->toString() << std::endl;
  catch (std::exception const &se) {
    std::cout << "ERROR - " << se.what() << std::endl;
  catch (...) {
    std::cout << "General error" << std::endl;
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20070918/b11031a5/attachment.html
