[geos-devel] How to destroy PreparedGeometry object?
Martin Davis mbdavis at refractions.net
Mon Aug 11 19:32:39 EDT 2008
Sure, sounds good - I agree with your reasoning.  Simpler is better!
Mateusz Loskot wrote:
> Martin Davis wrote:
>> Ugh.
>> Sounds like we need a
>> PreparedGeometryFactory::destroyPreparedGeometry(PreparedGeometry *)
>> method, then - as per your suggestion.
> or just
> PreparedGeometryFactory::destroy(PreparedGeometry* )
> as we have prepare() and create() but not preparePreparedGeometry etc.
> (Actually, I would vote for renaming destroyGeometry() to just
> destroy() from the same reasons, but I understand it's likely
> impossible as it breaks public API)
>> Does this same situation exist for all objects which might be
>> allocated on the heap?
> Yes, it does exist for all objects that:
> a) are allocated on the heap
> b) and are returned outside GEOS, to user
> c) and the ownership is transfered to user
> The c) means that a user is responsible for destroying it.
>> There's lots of classes in GEOS "below the Geometry level" which
>> might be used by a coder using the C++ API.  Perhaps there should be
>> a warning about this (in the non-existent FAQ?)
> Yes, FAQ is good, but empty:
> http://trac.osgeo.org/geos/wiki/FAQ
> The explanation can be stolen from GDAL FAQ with some changes related
> to GEOS. Before I compile something, I need to find more examples of
> potentially dangerous places in GEOS.
> Best regards
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
