[geos-devel] Delocalizing the WKT writer?
    Chris Hodgson
    chodgson at refractions.net
    Thu Aug 28 14:08:04 EDT 2008
Oh, now I understand - by "bracing the guts" you meant wrapping it with
those calls - I thought you meant commenting out those calls. With
Frank's suggested changes I expect your solution will do the job.
Chris
sgillies at frii.com wrote:
> Chris,
> The calls below were added for illustration, they are not in the source
> trunk. Sorry about the confusion. I haven't found any other calls to
> setlocale.
> Sean
>> I'm no locale expert, but it looks to me like that is the code that IS
>> de-localizing, setting to using the C locale instead of whatever the
>> locale is set to in the system? Are there other setlocale calls in the
>> writer code itself that undermine this?
>> Chris
>>> Can one of the C++ gurus explain why delocalizing the writer (to fix bug
>>> 201) isn't as simple as bracing the guts of this function with calls to
>>> setlocale()?
>>> capi/geos_c.cpp:
>>> char*
>>> GEOSWKTWriter_write(WKTWriter *writer, const Geometry *geom)
>>>     try
>>>                 // switch to C locale
>>>                 std::setlocale(LC_ALL, "C");
>>> 		std::string s = writer->write(geom);
>>> 		char *result;
>>> 		result = (char*) std::malloc( s.length() + 1);
>>> 		std::strcpy(result, s.c_str() );
>>>                 // switch back to native locale
>>>                 std::setlocale(LC_ALL, "");
>>> 		return result;
>>> 	catch (const std::exception &e)
>>> 		ERROR_MESSAGE("%s", e.what());
>>> 		return NULL;
>>> 	catch (...)
>>> 		ERROR_MESSAGE("Unknown exception thrown");
>>> 		return NULL;
>>> Sure, it would be nice to work this down into the C++ code, but the
>>> WKTWriter class is a nightmare.
>>> Sean
>>> geos-devel mailing list
>>> geos-devel at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geos-devel
