[geos-devel] [GEOS] #202: Undefined behavior in Coordinate::hashCode
GEOS geos-trac at osgeo.org
Thu Aug 28 20:11:13 EDT 2008
 Reporter:  mloskot      |       Owner:  geos-devel at lists.osgeo.org
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:
Component:  Core         |     Version:  svn-trunk
 Severity:  Significant  |    Keywords:  coordinate hash double
 If ./configure fails to detect availability of ''64-bit integer'', it sets
 ''int64'' typedef to ''long int'' (in file platform.h).
 In this case, when in64 is 32-bit wide, ''undefined behavior'' occurs in
 Coordiante::hashDouble() function:
 unsigned int Coordinate::hashCode(double d)
    int64 f = (int64)(d);
    return (int)(f^(f>>32)); // <--- UB
 According to the standards C (section 6.5.7/3) and C++ (section 5.8/1):
  ''The behavior is undefined if the right operand is negative, or greater
 than or equal to the length in bits of the promoted left operand.''
 This error occur in '''f>>32''', when ''sizeof(f) == 32''.
 Simple but not ideal fix could be:
 #include <cstring> // std::memcpy
 int Coordinate::hashDouble(double d)
    unsigned int arr[2] = { 0 };
    std::memcpy(arr, &x, sizeof(double));
    return (arr[0] ^ (((arr[1] >> 16) & 0x000000FF)
            | ((arr[1] >> 8) & 0x0000FF00)
            | ((arr[1] << 8) & 0x00FF0000)
            | ((arr[1] << 16) & 0xFF000000)));
Ticket URL: <http://trac.osgeo.org/geos/ticket/202>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
