[geos-devel] Compiling GEOS on Solaris 10 (x86)
Gregor Fikoczek gregor.fikoczek at wheregroup.com
Wed Dec 3 09:05:41 EST 2008
Hi list,
i am a "newbie" in Solaris and trying to compile geos-3.0.3 in Solaris 10
(x86):
bash-3.00# cd geos-3.0.3
bash-3.00# export LD_LIBRARY_PATH=/usr/lib:/usr/local/lib
bash-3.00# env PATH=/usr/local/bin:/usr/bin ./configure
bash-3.00# env PATH=/usr/local/bin:/usr/bin:/usr/ccs/bin make
But I'm getting always the error:
rminant.o .libs/SIRtreePointInRing.o .libs/SimplePointInAreaLocator.o .libs/SimplePointInRing.o
make[2]: *** [libalgorithm.la] Error 1
make[2]: Leaving directory `/Documents/Download/geos-3.0.3/source/algorithm'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/Documents/Download/geos-3.0.3/source'
make: *** [all-recursive] Error 1
After executing the Patch
http://trac.osgeo.org/geos/attachment/ticket/205/geos-solaris-1.diff
(http://trac.osgeo.org/geos/ticket/205)
i still get the same error.
I also tried with the geos-trunk sources(gdal-3.1.0) and get an other error:
false
cru .libs/liblocation.a .libs/IndexedPointInAreaLocator.o .libs/PointOnGeometryLocator.o  .libs/SimplePointInAreaLocator.o
make[4]: *** [liblocation.la] Error 1
make[4]: Leaving directory
`/Documents/Download/geos-3.1.0/source/algorithm/locate'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/Documents/Download/geos-3.1.0/source/algorithm'
make[1]: Leaving directory `/Documents/Download/geos-3.1.0/source'
Am doing something wrong ? Are there any Options i have to set by 'make' ?
Best Regards,
Gregor
Where2B-Konferenz
Die Geo-IT Konferenz der WhereGroup
vom 9.-10. Dezember 2008 in Bonn
Web: www.where2b-conference.com
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Gregor Fikoczek
Email: gregor.fikoczek at wheregroup.com
Fon: +49 (0)228 / 90 90 38 - 25
Fax: +49 (0)228 / 90 90 38 - 11
info at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
