[geos-devel] Minimum Bounding Circle
Obe, Regina robe.dnd at cityofboston.gov
Mon Dec 29 12:57:26 EST 2008
I was snooping around the GEOS library and noticed a curious algorithm class
called MinimumDiameter.  As far as I can tell from scanning the code,
it seems similar in concept to the the Minimum Bounding Circle plpgsql algorithm that
Bruce posted in November
http://postgis.refractions.net/pipermail/postgis-users/2008-October/021734.html
Just wondering why this is not exposed in the CAPI interface or does it server an entirely different purpose from what I am thinking.
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20081229/38085595/attachment.html
