[geos-devel] Bug in buffer function?
Silke Reimer reimer at rapideye.de
Fri Feb 8 03:29:06 EST 2008
On Wednesday 06 February 2008, Homme Zwaagstra wrote:
> Hello,
> Not too much help, I know, but things do look amiss! The following WKB
> also fails with buffer(-2). It is almost identical to the second WKB
> in your post (and which produces a valid buffer), differing only at
> around the 15th decimal place (didn't check exactly!):
> 010300000001000000090000006666666666D679403433333333636E406666666666FA82406
>666666666866E400000000000F8824066666666666E72403333333333CF85406666666666767
>2409A99999999D985409A99999999396E4066666666660E7A40CCCCCCCCCC1C6E40343333333
>30B7A409A999999994964403433333333D379409A999999994964406666666666D6794034333
>33333636E40
Thanks, Homme, for this analysis. The result means to me that there is indeed
a bug in the buffer function. Thus I will create a ticket in the bug tracker.
Perhaps I will have time to dig a bit deeper into the code to find out why the
buffer function behaves like that. I will keep you informed and of course I
appreciate any more comments about this issue.
Greetings,
	Silke
phone: +49 3381 8904318		 fax:   +49 3381 8904101
RapidEye AG
Molkenmarkt 30
14776 Brandenburg an der Havel
Germany
Head Office/Sitz der Gesellschaft: Brandenburg an der Havel
Management Board/Vorstand: Wolfgang G. Biedermann
Chairman of Supervisory Board/Vorsitzender des Aufsichtsrates: Axel Schmalz
Commercial Register/Handelsregister Potsdam HRB 17 796
Tax Number/Steuernummer: 048/100/00053
VAT-Ident-Number/Ust.-ID: DE 199331235
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte
Informationen. Wenn Sie nicht der richtige Adressat sind oder diese
E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den
Absender und vernichten Sie diese E-Mail. Das unerlaubte Kopieren sowie
die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
The information in this e-mail is intended for the named recipients
only. It may contain privileged and confidential information. If you
have received this communication in error, any use, copying or
dissemination of its contents is strictly prohibited. Please erase all
copies of the message along with any included attachments and notify
RapidEye AG or the sender immediately by telephone at the number
indicated on this page.
