[geos-devel] Compiling troubles
Paul Ramsey pramsey at refractions.net
Wed Jan 2 16:41:35 EST 2008
You might have to pre-make the target directories...
mkdir $INSTALL/bin
mkdir $INSTALL/lib
mkdir $INSTALL/include
P.
On 2-Jan-08, at 1:33 PM, Meek, Allan (Contractor) wrote:
> Hi Mateusz,
> Whoops. My configure line was actually "./configure --prefix=$
> {INSTALL}"
> so that things would be installed in /rde/ameek/GEOS/binlin. So, I
> wouldn't need sudo to run "make install".
> I think my biggest question is this: What does Error 126 mean?
> Thanks for your help,
> Allan
> -----Original Message-----
> From: geos-devel-bounces at lists.osgeo.org
> [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Mateusz
> Loskot
> Sent: January 2, 2008 4:30 PM
> To: GEOS Development List
> Subject: Re: [geos-devel] Compiling troubles
>> Hi,
>> I just downloaded geos-3.0.0.tar.bz2 today and tried to compile it in
>> Red Hat Linux, but I have encountered some troubles.
>> Here are the steps I followed:
>> - extracted the contents of the tar file to /rde/ameek/GEOS/
>> geos-3.0.0
>> - set the INSTALL environmental variable to /rde/ameek/GEOS/binlin
>> - created the directory /rde/ameek/GEOS/binlin
>> - from the geos-3.0.0 directory, executed "./configure
>> --prefix=${INSTALL}"
>> - executed "make"; everything looked good
>> - executed "make check"; everything looked good
>> - executed "make install"; I ended up with the following error
> messages:
> Allan,
> Shouldn't the last command read:
> sudo make install
> unless you have sufficient privs to write to prefix location?
> I just tested GEOS from SVN and make install command works perfectly
> well for me. I assume both SVN and 3.0.0 makefiles are correct.
> Cheers
> Mateusz Loskot
> http://mateusz.loskot.net
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
