[geos-devel] GEOS 3 DLLs?
Sean Gillies sgillies at frii.com
Sun Jan 13 14:34:19 EST 2008
Thanks, Artem. Once I got the redistributable package with msvcp80.dll
it worked fine. That is standard on XP, yes?
Charlie, Mark: thanks too.
Sean
Artem Pavlenko wrote:
> Hi Sean,
> You can get  geos 3 dlls (+libs) from :
> http://artem.dev.openstreetmap.org/files/geos_3.zip
> Or you can always build them yourself using VC++ express (free as in beer):
> nmake /f Makefile.vc
> HTH
> Cheers
> Artem
> On 12 Jan 2008, at 21:07, Sean Gillies wrote:
>> Can anyone share GEOS 3 DLLs (including the C API) with me? I tried to
>> get them out of the PostGIS 1.3.2 installer, but that appeared to
>> require installing Postgres and I'm unwilling to do that.
>> Thanks,
>> Sean
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geos-devel
