[geos-devel] Bug in buffer function?
Silke Reimer reimer at rapideye.de
Fri Jan 25 09:26:59 EST 2008
Hallo!
I observed a really strange behavior of the buffer function when using an
inner buffer. The error occurs with the following geometry:
POLYGON ((
513.4 343.1,
707.3 344.2,
707.0 394.9,
797.9 395.4,
799.2 341.8,
516.9 340.9,
516.7 262.3,
513.2 262.3,
513.4 343.1
Its WKB representation is
0103000000010000000900000033333333330B80409A9999999971754066666666661A8640333333333383754000000000001886406666666666AE78403333333333EF88406666666666B678409A99999999F98840CDCCCCCCCC5C7540333333333327804066666666664E75409A99999999258040CDCCCCCCCC6470409A99999999098040CDCCCCCCCC64704033333333330B80409A99999999717540
Using a buffer of -2 should lead to an inner buffer but leads
to "GEOMETRYCOLLECTION EMPTY" resp. "POLYGON( EMPTY)" depending on the geos
version.
Using the same buffer of -2 on a polygon with the same shape but shifted to
the left by 100 and shifted down by 100, i.e.
POLYGON ((
413.4 243.1,
607.3 244.2,
607.0 294.9,
697.9 295.4,
699.2 241.8,
416.9 240.9,
416.7 162.3,
413.2 162.3,
413.4 243.1
resp.
010300000001000000090000006666666666D679403333333333636E406666666666FA82406666666666866E400000000000F8824066666666666E72403333333333CF854066666666667672409A99999999D985409A99999999396E4066666666660E7A40CDCCCCCCCC1C6E4033333333330B7A409A999999994964403333333333D379409A999999994964406666666666D679403333333333636E40
leads to the expected buffer:
POLYGON((609.172261037685 243.512992930268,609.26383338939
243.821372982058,609.29996498814 244.211834112356,609.011804031568
292.911035772954,695.948180429531 293.389233662932,697.151062564334
243.793477951075,609.172261037685 243.512992930268))
resp.
01030000000100000007000000DD1965CA600983408D5226706A706E403118AE541C0A83402AF8FDAF487A6E400A300B54660A8340DB175558C7866E405E4CB62C1808834035253F9A934E72405BFC9EDF95BF8540BECC134D3A567240B72B4A6035C98540EB3EDF2B64796E40DD1965CA600983408D5226706A706E40
I tested this on different geos versions among them
3.0.0rc4 and 3.0.0
I would say that this is a bug but it would be nice if somebody could confirm
this - and perhaps you even have an idea how to solve this? I did not find
any entry in the bug tracker but maybe I just missed it. In this case I would
be glad for a hint.
Many greetings,
	Silke
RapidEye AG
Molkenmarkt 30
14776 Brandenburg an der Havel
Germany
Head Office/Sitz der Gesellschaft: Brandenburg an der Havel
Management Board/Vorstand: Wolfgang G. Biedermann
Chairman of Supervisory Board/Vorsitzender des Aufsichtsrates: Axel Schmalz
Commercial Register/Handelsregister Potsdam HRB 17 796
Tax Number/Steuernummer: 048/100/00053
VAT-Ident-Number/Ust.-ID: DE 199331235
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte
Informationen. Wenn Sie nicht der richtige Adressat sind oder diese
E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den
Absender und vernichten Sie diese E-Mail. Das unerlaubte Kopieren sowie
die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
The information in this e-mail is intended for the named recipients
only. It may contain privileged and confidential information. If you
have received this communication in error, any use, copying or
dissemination of its contents is strictly prohibited. Please erase all
copies of the message along with any included attachments and notify
RapidEye AG or the sender immediately by telephone at the number
indicated on this page.
