[geos-devel] Re: [postgis-users] ST_Contains doesn't work?
Martin Davis mbdavis at refractions.net
Fri Jan 25 11:38:40 EST 2008
The original code is correct as it stands.   Your fix works because it
just removes a potential optimization.
The fix that Ben posted is the correct one (and has been implemented in
JTS as well).
KXK wrote:
> Paul & Ben J.
> I found a quick solution for this "Contains" problem.
> These 3 lines below should be deleted to fix this bug.
> source/geom/Geomtry.cpp
> bool
> Geometry::contains(const Geometry *g) const
> 	if (isRectangle()) {
> 		return predicate::RectangleContains::contains((Polygon&)*this, *g);
> // Delete from here
> 	if (g->isRectangle()) {
> 		return predicate::RectangleContains::contains((const Polygon&)*g, *this);
> // Delete until here
> The reason why I thought of deleting these 3 lines was:
> The 1st argument should be passed as the 2nd argument,
> and the 2nd argument should be passed as the 1st argument,
> because it should varify if *this contains *g. Not the other way around.
> BUT, predicate::RectangleContains::contains method accepts the 1st
> argument only being a rectangle.
> So, passing *this as the 1st argument is not acceptable since *this is
> not guaranteed as a rectangle; it is just a geometry.
> I will put this info to the below site, too.
> http://trac.osgeo.org/geos/
> What do you think about the solution? I need your feedbacks.
> Good Day,
> KXK
> 2008/1/18, KXK <vivahome2 at gmail.com>:
>> Paul
>> Thanx for a quick reply.
>> At http://trac.osgeo.org/geos, I issued a ticket whose number is #171.
>> KXK
>> 2008/1/18, Paul Ramsey <pramsey at refractions.net>:
>>> I think this must be arising in the "I'm a box so I can short-circuit
>>> full computation" code. The error displays with different combinations
>>> of square and non-square arguments.
>>> On Jan 17, 2008, at 7:55 PM, Paul Ramsey wrote:
>>>> I just confirmed this behavior. true/true on geos 2.2 true/false on
>>>> geos 3.0.
>>>> Please file this at http://trac.osgeo.org/geos, it's real, and it's
>>>> not right.
>>>> P
>>>> On Jan 17, 2008, at 7:35 PM, KXK wrote:
>>>>> SELECT
>>>>> ST_Contains(
>>>>> GeomFromText('POLYGON((0 0,0 10,10 10,10 0,0 0))', -1),
>>>>> GeomFromText('POLYGON((5 5,5 6,6 6,6 5,5 5))', -1) );
>>>>> returns TRUE
>>>>> But,
>>>>> SELECT
>>>>> ST_Contains(
>>>>> GeomFromText('POLYGON((0 0,0 11,11 10,10 0,0 0))', -1),
>>>>> returns FALSE
>>>>> I thought the above would also return TRUE.
>>>>> Is this behavior of ST_Contains correct?
>>>>> [VERSION INFORMATION]
>>>>> OS: fc6
>>>>> PostgreSQL: 8.2.4
>>>>> PostGIS: 1.2
>>>>> GEOS: 3.0.0
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> postgis-users at postgis.refractions.net
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>> geos-devel mailing list
>>>> geos-devel at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geos-devel
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
