[geos-devel] C-API extension
Jürgen E. Fischer
jef at norbit.de
Wed Jul 30 16:38:45 EDT 2008
Hi there,
while porting Quantum GIS from the C++ API to the C API I found that
there currently seems to be no way to get the cut edges from
the Polygonizer.
Please consider the attached patch, which adds that.
tia
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-0
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
Index: capi/geos_c.cpp
--- capi/geos_c.cpp (revision 2135)
+++ capi/geos_c.cpp (working copy)
@@ -1349,6 +1349,54 @@
Geometry *
+GEOSPolygonizeGetCutEdges(const Geometry * const * g, unsigned int ngeoms)
+ using geos::operation::polygonize::Polygonizer;
+ unsigned int i;
+ Geometry *out = NULL;
+ try{
+ // Polygonize
+ Polygonizer plgnzr;
+ for (i=0; i<ngeoms; i++) plgnzr.add(g[i]);
+#if GEOS_DEBUG
+ NOTICE_MESSAGE("geometry vector added to polygonizer");
+#endif
+ std::vector<const LineString *>*lines = plgnzr.getCutEdges();
+#if GEOS_DEBUG
+ NOTICE_MESSAGE("output polygons got");
+#endif
+ // We need a vector of Geometry pointers, not
+ // Polygon pointers.
+ // STL vector doesn't allow transparent upcast of this
+ // nature, so we explicitly convert.
+ // (it's just a waste of processor and memory, btw)
+ std::vector<Geometry*> *linevec =
+ new std::vector<Geometry *>(lines->size());
+ for (i=0; i<lines->size(); i++) (*linevec)[i] = (*lines)[i]->clone();
+ out = geomFactory->createGeometryCollection(linevec);
+ // the above method takes ownership of the passed
+ // vector, so we must *not* delete it
+ catch (const std::exception &e)
+ ERROR_MESSAGE("%s", e.what());
+ return NULL;
+ catch (...)
+ ERROR_MESSAGE("Unknown exception thrown");
+ return NULL;
+ return out;
+Geometry *
GEOSLineMerge(const Geometry *g)
using geos::operation::linemerge::LineMerger;
Index: capi/geos_c.h.in
--- capi/geos_c.h.in (revision 2135)
+++ capi/geos_c.h.in (working copy)
@@ -283,8 +283,8 @@
* all arguments remain ownership of the caller
* (both Geometries and pointers)
-extern GEOSGeometry GEOS_DLL *GEOSPolygonize(const GEOSGeometry * const geoms[],
- unsigned int ngeoms);
+extern GEOSGeometry GEOS_DLL *GEOSPolygonize(const GEOSGeometry * const geoms[], unsigned int ngeoms);
+extern GEOSGeometry GEOS_DLL *GEOSPolygonizeGetCutEdges(const GEOSGeometry * const geoms[], unsigned int ngeoms);
extern GEOSGeometry GEOS_DLL *GEOSLineMerge(const GEOSGeometry* g);
extern GEOSGeometry GEOS_DLL *GEOSSimplify(const GEOSGeometry* g1, double tolerance);
