[geos-devel] An Immodest Proposal
Martin Davis mbdavis at refractions.net
Wed Oct 1 18:00:06 EDT 2008
So Chris is saying almost the same thing I am - except I don't think you
ever have to free the static factory object.
Chris Hodgson wrote:
> If we're willing to accept a bit of a hack, you could just check in
> your overridden free() if the thing being free()'d was the global
> geomFactory, and if so, always use regular free().
> This would have no effect on programs that aren't specifying their own
> memory functions (other than the additional instructions to execute on
> every call to free() ), and I think it would solve the problem as
> you've stated it.
> Chris
> Paul Ramsey wrote:
>> So, moving the instantiation of geomFactory object into initGEOS did
>> nothing for me, the object is still allocated by malloc, not palloc,
>> perhaps because it's a global, so it's getting set up at library load
>> time?
>> Putting the whole factory and creation process inside the function
>> bodies could get very expensive, since the functions are called
>> repetitively a lot, which means each call would do a newfactory,
>> newgeo, destroygeom, destroyfactory (ack!).  This is presumably why
>> the factory was made into a global outside the functions.
>> I'm at an impasse. If new/delete are overridden, when the end of a
>> postgres comes along, the system will attempt to pfree the globals as
>> it cleans up the library, and since the globals are malloc'ed,
>> segfault ensues.
>> If we backtrack to not over-riding new/delete, then we have the
>> problem of leaking the prepared objects at the end of each
>> transaction.
>> P.
>> On Wed, Oct 1, 2008 at 11:08 AM, Paul Ramsey
>> <pramsey at cleverelephant.ca> wrote:
>>> So, using a longer lived memory context I can get right to the end of
>>> a query before the segfault arrives. The segfault happens when
>>> deleting a geometryfactory at the end, which tells me a couple things,
>>> I think.
>>> First, those two std allocs that sneak in before we over-ride new are
>>> related to the geometry factory. The segfault happens when we're
>>> trying to pfree the geometryfactory.
>>> The offending code is this in geos_c.cpp:
>>> // NOTE: SRID will have to be changed after geometry creation
>>> static const GeometryFactory *geomFactory =
>>>        GeometryFactory::getDefaultInstance();
>>> This global geomFactory is called a number of times by WKB readers and
>>> some other functions.  I wonder if we can initialize it in initGEOS
>>> and clean it up in finishGEOS?
>>> It appears, that this is what used to happen? Here's the current code.
>>> void
>>> finishGEOS ()
>>>        // Nothing to do
>>>        //delete geomFactory;
>>> Any help on the history behind this global?
>>> P.
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geos-devel
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
