[geos-devel] Repackaging releases
Kurt Schwehr schwehr at ccom.unh.edu
Fri Oct 17 16:16:49 EDT 2008
The joys of software release :)
As a packager of geos in fink, I would suggest going to 3.0.2.  Using
the -1 -2 -3 series will get confusing at best.  Tars that change
make things happen that confuse the packagers, the users, and the
mirroring systems.
Thanks,
-kurt
> OK, now it's back to 1.5.26, hopefully that helps.
> P
> Paul,
> Speaking as someone who has in the past repackaged releases and then
> suffered substantial criticism from "downstream", I'd encourage you to
> actually issue updates as 3.0.2 and so forth even if only updating
> stuff
> like libtool.
> 3.0.2 or 3.0.1-1?
> P.
> The 3.0.1-1, and 3.0.1-2 would normally indicate particular packaging
> attempts against a fixed 3.0.1 source tarball.  So the "dash
> series" is
> really naming reserved for packagers (Debian, OSGeo4W, etc) rather
> than
> source releases from the projects.
