[geos-devel] 3.0.3 To Do
Obe, Regina robe.dnd at cityofboston.gov
Wed Oct 22 15:26:17 EDT 2008
Paul,
You're going to miss some minor dramas if you keep on sleeping like this
He did test on mingw but not Visual C++.  Think we need a Visual C++
tester.  I presume it should compile in that.  I would myself, but
haven't quite figured out how that side of Visual Studio works.
http://postgis.refractions.net/pipermail/postgis-devel/2008-October/0039
67.html
Though he did say GeoJSON regression test fails.
-----Original Message-----
[mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
Sent: Wednesday, October 22, 2008 3:11 PM
To: GEOS Development List
Subject: Re: [geos-devel] 3.0.3 To Do
No, I'm pretty sure he said he'd do it when he got time.
P
On Wed, Oct 22, 2008 at 12:04 PM, Obe, Regina
<robe.dnd at cityofboston.gov> wrote:
> Didn't Mark Cave-Ayland already do that and say it worked?
> ________________________________
> From: geos-devel-bounces at lists.osgeo.org on behalf of Paul Ramsey
> Sent: Wed 10/22/2008 3:03 PM
> You're right, the removal of strdup was in your patch already... so, I
> guess we just need a Windoze volunteer to compile branch 3.0.
> P.
> On Wed, Oct 22, 2008 at 11:58 AM, Obe, Regina
> wrote:
>> Wasn't the CLocalizer change in trunk already.  It should have been
in my
>> patch since I took the CLocalizer.cpp and .h from trunk since I
couldn't
>> get
>> it to compile otherwise.  Or hmm I think I that was the one that I
>> couldn't
>> just add the header line.
>> Sent: Wed 10/22/2008 2:57 PM
>> Subject: [geos-devel] 3.0.3 To Do
>> Well, that was fast...
>> I've applied Regina's patch so we should compile under new GCC and
>> hopefully Windows too? We have a patch to CLocalizer that needs to go
>> in and be tested on Windows.
>> Sean, how about you commit the patch and then we can have the Windows
>> people test off of SVN. If it's not working we can fix it up post
>> facto.
>> Is there anything else outstanding on the 3.0 branch standing in
front
>> of another point release?
>> Paul
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geos-devel
>> The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure
pursuant to
>> Massachusetts law. It is intended solely for the addressee. If you
>> received
>> this in error, please contact the sender and delete the material from
any
>> computer.
>> Help make the earth a greener place. If at all possible resist
printing
>> this
>> email and join us in saving paper.
pursuant to
received
any
> computer.
printing this
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
