[geos-devel] 3.0.3 To Do
Thu Oct 23 11:36:48 EDT 2008
Obe, Regina wrote:
> I know Frank already tested on Visual C++ Express (which is basically
> Visual 2008 Express) and got some test fail errors.  Do we have a
> solution file for that (or would people just use the msvc80 solution
> file for that if they wanted to use a solution) .
> Running regression tests using geos_unitd.exe...
>   GEOS Test Suite Application
> capi::GEOSCoordSeq: ..... 5
> capi::GEOSSimplify: . 1
Folks,
I would note that I wasn't running geos_unitd.exe, I ran geostest.exe
against capi/test.wkt and compared to capi/test.expected.  If I get
back to my windows build I'll look into the geos_unitd.exe which I wasn't
aware of.
Best regards,
