[geos-devel] 3.0.3 To Do
Paul Ramsey pramsey at cleverelephant.ca
Fri Oct 24 11:50:26 EDT 2008
I tried the earlier one and that didn't work either. I'm suspecting my
OS/X patch is (a) first stripping the CRs from the dos-generated patch
and then (b) not finding any matches in the dos-formatted target file.
I think someone else with a cygwin sandbox should apply this patch.
P.
On Fri, Oct 24, 2008 at 8:46 AM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
> Paul,
> The earlier one doesn't add any new files so may be more appropriate.
> This one adds a new geostest folder to the msvc80 and geostest to the
> solution to add the test that Frank was running using make.vc (that does
> the test.wkt compare thing).
> Note:  this geostest isn't even in trunk so I'm questioning if we really
> want to include it in the geos 3.0 branch. If we do we should include it
> in trunk to be consistent.
> Since we already have a unit test for VC and the unit test is much
> easier to use than the geostest, I question the value of adding this
> extra project to the solution.
> Thanks,
> Regina
> -----Original Message-----
> From: geos-devel-bounces at lists.osgeo.org
> [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
> Sent: Friday, October 24, 2008 11:39 AM
> To: GEOS Development List
> Subject: Re: [geos-devel] 3.0.3 To Do
> On Thu, Oct 23, 2008 at 9:48 PM, Obe, Regina <robe.dnd at cityofboston.gov>
> wrote:
>> Actually which patch are you referring to.  The version one or the big
>> patch.  I just redownloaded the msvc80 folder from svn that has your
> version
>> patch and then reapplied Sanak's patch and didn't run into any
> conflicts.
> this one
> geos-branches-3.0-build-msvc80_add_geostest.patch
> should I be doing the earlier one?
> P
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
