[geos-devel] 3.0.3 To Do
Sean Gillies sgillies at frii.com
Fri Oct 24 12:35:09 EDT 2008
According to
http://trac.osgeo.org/geos/log/branches/3.0/capi/geos_c.cpp
The C API hasn't changed since the 3.0 branch was made, so a change of
the API version number isn't warranted.
Sean
Paul Ramsey wrote:
> I couldn't apply this patch cleanly, could someone else try?
> P.
> On Thu, Oct 23, 2008 at 10:52 AM, Sanak <geosanak at gmail.com> wrote:
>> Ok, I had added geostest project to msvc80 solution file.
>> Please see the attach
>> file(geos-branches-3.0-build-msvc80_add_geostest.patch).
>> geostest.vcproj will generate capi/test.out.
>> I think that the cause of difference between generated test.out and
>> test.expected is precision of floating point, but I don't know details.
>> And another Visual C++ specific problem may be capi
>> version.(capi/geos_c.h.in)
>> Index: geos_c.h.in
>> --- geos_c.h.in    (revision 2208)
>> +++ geos_c.h.in    (working copy)
>> @@ -51,9 +51,9 @@
>>  #if defined(_MSC_VER)
>>  #include <geos/version.h>
>>  #define GEOS_CAPI_VERSION_MAJOR 1
>> -#define GEOS_CAPI_VERSION_MINOR 3
>> +#define GEOS_CAPI_VERSION_MINOR 4
>>  #define GEOS_CAPI_VERSION_PATCH 3
>> -#define GEOS_CAPI_VERSION "3.0.0rc4-CAPI-1.3.3"
>> +#define GEOS_CAPI_VERSION "3.0.3-CAPI-1.4.3"
>>  #else
>>  #define GEOS_VERSION_MAJOR @VERSION_MAJOR@
>>  #define GEOS_VERSION_MINOR @VERSION_MINOR@
>> Regards,
>> 2008/10/24 Frank Warmerdam <warmerdam at pobox.com>
>>> Obe, Regina wrote:
>>>> I know Frank already tested on Visual C++ Express (which is basically
>>>> Visual 2008 Express) and got some test fail errors.  Do we have a solution
>>>> file for that (or would people just use the msvc80 solution file for that if
>>>> they wanted to use a solution) .
>>>> Running regression tests using geos_unitd.exe...
>>>>  GEOS Test Suite Application
>>>> capi::GEOSCoordSeq: ..... 5
>>>> capi::GEOSSimplify: . 1
>>> Folks,
>>> I would note that I wasn't running geos_unitd.exe, I ran geostest.exe
>>> against capi/test.wkt and compared to capi/test.expected.  If I get
>>> back to my windows build I'll look into the geos_unitd.exe which I wasn't
>>> aware of.
>>> Best regards,
>>> I set the clouds in motion - turn up   | Frank Warmerdam,
>>> light and sound - activate the windows | http://pobox.com/~warmerdam
>>> and watch the world go round - Rush    | Geospatial Programmer for Rent
>>> geos-devel mailing list
>>> geos-devel at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geos-devel
