[geos-devel] Fw: 3.0?
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Thu Oct 30 10:53:14 EDT 2008
> Dear all,
> I tried running compiling using the latest geos-svn.tar.gz (yesterday
> evening) which contained the modification mentioned below. Unfortunately
> it gave the same errors as before i.e:
> ....... multiple definition of`geos::operation::overlay
> ::MinimalEdgeRing::~MinimalEdgeRing()'
> .libs/inlines.o:/home/Stevo/geos-3.1.0/source/../source/headers/geos/operation/overlay/MinimalEdgeRing.inl:43:
> first defined here
> Creating library file: .libs/libgeos.dll.a
> collect2: ld returned 1 exit status
> make[2]: *** [libgeos.la] Error 1
> make[2]: Leaving directory `/home/Stevo/geos-3.1.0/source'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/home/Stevo/geos-3.1.0/source'
> So not sure how I got it to work on my system, looks like I've got
> beginners luck!
> Sorry I can't help
> Regards
> Stephen
Hi Stephen,
Hmmmm that's a pain. You mentioned that you'd altered the headers
according to one of my earlier emails and the compilation worked? So in
that case what is the difference between the version you did manage to
compile, and what is currently in SVN?
ATB,
Mark.
