[geos-devel] OverlayOp JTS port
Obe, Regina robe.dnd at cityofboston.gov
Wed Sep 17 14:00:15 EDT 2008
I apologize for the barrage of questions.  As far as I can tell the
OverlayOp.cpp is vintage JTS 1.7 (which I think is same as the JTS 1.9 for this class)
except it has the additional calls of
checkObviouslyWrongResult() - which most of that code looks like it would never
be called because of the #ifdefs except for the
assert(resultGeom);
UNREFERENCED_PARAMETER(opCode); (have no clue what this does)
and also a
elevationMatrix->elevate(resultGeom);
which looks like will get called since USE_ELEVATION_MATRIX 1.
Is the elevationMatrix designed to deal with 3d geometries?  Didn't realize
Union actually works with those, but then I never tried it with 3d.
So I'm a little puzzled why these 2 extra function calls since I always thought
GEOS was at best on par with JTS?
Thanks,
Regina
-----Original Message-----
From: geos-devel-bounces at lists.osgeo.org on behalf of Obe, Regina
Sent: Wed 9/17/2008 9:26 AM
To: GEOS Development List
Subject: [geos-devel] OverlayOp JTS port
I'm looking at the operation.overlay.OverlayOp in geos trunk
In the header it says
Last port: operation/overlay/OverlayOp.java rev. 1.23
But I don't believe this to be right since when I compare the
computeOverlay methods
against 1.2 and 1.3 versions of JTS codebase, it has an additional
EdgeNodingValidator check which wasn't introduced until later versions
of JTS.
So I'm wondering is the OverlayOp.cpp a mix of JTS versions or is the
comment above just plain wrong.
It also has a checkObviouslyWrongResult() check at the end of
computerOverlay which I haven't figured out which version that was
introduced in JTS (its not in 1.2,1.3, or 1.9).  Is this a GEOS specific
check that has no JTS equivalent?
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
geos-devel mailing list
geos-devel at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geos-devel
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20080917/7c5d8116/attachment.html
