[geos-devel] An Immodest Proposal
Gregory Williamson Gregory.Williamson at digitalglobe.com
Mon Sep 29 18:54:07 EDT 2008
This sounds like the most rational way forward on a gnarly problem.
+1
Greg W.
Senior DBA
DigitalGlobe
-----Original Message-----
From: geos-devel-bounces at lists.osgeo.org on behalf of Paul Ramsey
Sent: Mon 9/29/2008 1:42 PM
To: GEOS Development List
Subject: [geos-devel] An Immodest Proposal
All,
We are currently grappling with a pretty big issue in the PostGIS/GEOS
integration, namely that PgSQL allocates it's memory inside pools
(palloc/pfree), while GEOS allocates in general memory (malloc/free).
This (a) imposes a requirement of memory management perfection on
GEOS, otherwise the long-running postgres processes will leak and (b)
can lead to insoluble problems in certain implementation patterns.
We have recently found one such problem pattern. When using
preparedgeometry in postgis, we create a GEOS geometry and associated
prepared geometry, these are duly malloc'ed, but we store references
to them in a palloc'ed struct in a memory pool which lasts for the
life of a postgres query.  All is good (well, there are memory leaks
in the prepared stuff still, but those are theoretically fixable)
until the end of the query, when postgres cleans up the query memory
pool. All of a sudden the struct with the references to the geometry
and prepared geometry are gone -- but the objects have not been freed.
Basically, the prepared geometry system will leak one geometry and one
prepared geometry for every SQL statement run, and there's SFA we can
do about it.
My immodest proposal is to use geosInit as a location where users can
provide their own allocator/deallocators.  Right now, geosInit lets us
set custom error handlers, so this extends the idea further.
In GEOS we would override new/delete in GEOS to our own functions that
would check and see if the custom alloc/dealloc functions were set. If
not, they would fall back to malloc/free, otherwise use what was
provided.  For postgis, we would provide palloc/pfree in our geosInit
calls.
In this way, we could hook GEOS into the PgSQL pool system at runtime,
while still have it operate in the normal way when used with other
applications. And other applications with their own memory systems
could also more tightly integrate GEOS.
Thoughts?
P.
geos-devel mailing list
geos-devel at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geos-devel
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20080929/b1285772/attachment.html
