[geos-devel] An Immodest Proposal
Paul Ramsey pramsey at cleverelephant.ca
Tue Sep 30 19:47:56 EDT 2008
With attachments...
On Tue, Sep 30, 2008 at 4:47 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> Help!
> I've attached the modified geos_c.cpp and geos_c.h.in files for geos
> for your perusal. The symptom is this:
> - Modified containsPrepared to use initGEOSMemory
> - Run an ST_Contains(g,g,i) prepared example
> - Memory is both allocated and deallocated through the over-ridden
> functions just fine
> - UNTIL
> - The code gets to the point where it has to deallocate a prepared
> geometry and runs GEOSPreparedGeom_destroy()
> - At that point, the deallocation does *not* enter the over-ridden
> new/delete operators, it appears to use default operators, and
> everything goes boom
> So,
> - the over-ride of new/delete seems to work fine inside the main geos
> library, things get both allocated and freed using palloc and pfree
> - but the delete inside the "extern C {}" block where
> GEOSPreparedGeom_destroy does *not* appear to be over-ridden by our
> cunning trick
> Anyone have the secret sauce?
> P.
> On Tue, Sep 30, 2008 at 10:36 AM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>> Time to try this in "real life" with PostgreSQL and palloc/pfree.  I'm
>> going to create GEOS and PostGIS experimental branches, and commit my
>> work there, so that folks with other platforms can try it out.
>> On Tue, Sep 30, 2008 at 9:55 AM, Chris Hodgson <chodgson at refractions.net> wrote:
>>> Very nice Paul.
>>> Those two std allocs are a bit scary... I had a feeling we might have some
>>> of those, and they seem worse than I had initially thought. The problem is
>>> that either they are attempted to be freed, using the provided free function
>>> - and who knows what error that could bring - or they are not, and we're
>>> leaking. If they are only created once at load of the DLL and never actually
>>> freed, but simply go away when the DLL is unloaded, then I guess we're ok.
>>> But it seems likely to me that the C++ runtime would be trying to free them
>>> using your own provided free function... can we do a test where we provide
>>> pfree and see what it does with that? ie. if you try to pfree() a regularly
>>> malloc()'d segment of memory, does it actually free it without raising any
>>> errors?
>>> It would be really nice to know what those things that are getting created
>>> earlier are, too...
>>> but I guess it all just comes down to, does it work in postgres and not
>>> leak?
>>> Chris
>>> Paul Ramsey wrote:
>>>> It turns out it is a quite small modification, and works pretty well:
>>>> http://trac.osgeo.org/geos/attachment/ticket/208/memdiff.patch
>>>> My patch adds the ability to override, and also has some printfs to
>>>> show what is happening. When the overridden allocator is called
>>>> without the runtime callback set, it prints "std alloc" and when it's
>>>> called with the callback set, it prints "geos alloc".
>>>> Here's a little program that exercises it:
>>>> #include <stdio.h>
>>>> #include "/usr/local/include/geos_c.h"
>>>> #include <stdlib.h>
>>>> int main() {
>>>>  printf("main\n");
>>>>  GEOSCoordSequence* cs;
>>>>  GEOSGeometry* g;
>>>>  int r;
>>>>  printf("initgeos\n");
>>>>  initGEOSMemory(malloc, free);
>>>>  printf("coordseqcreate\n");
>>>>  cs = GEOSCoordSeq_create(1, 2);
>>>>  printf("coordseqsetx\n");
>>>>  r = GEOSCoordSeq_setX(cs, 0, 1.0);
>>>>  printf("coordseqsety\n");
>>>>  r = GEOSCoordSeq_setY(cs, 0, 1.0);
>>>>  printf("createpoint\n");
>>>>  g = GEOSGeom_createPoint(cs);
>>>>  return 0;
>>>> And here is the output:
>>>> Heron:tmp pramsey$ ./a.out
>>>> std alloc!
>>>> std alloc!
>>>> main
>>>> initgeos
>>>> coordseqcreate
>>>> geos alloc!
>>>> geos alloc!
>>>> geos alloc!
>>>> coordseqsetx
>>>> coordseqsety
>>>> createpoint
>>>> geos alloc!
>>>> So, something in C++ is doing a couple allocations before we can slip
>>>> in and get our other function in place. But we can get all the big
>>>> stuff caught no problem.
>>>> P.
>>>> _______________________________________________
>>>> geos-devel mailing list
>>>> geos-devel at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geos-devel
 * $Id: geos_c.cpp 2195 2008-09-29 19:24:06Z pramsey $
 * C-Wrapper for GEOS library
 * Copyright (C) 2005-2006 Refractions Research Inc.
 * This is free software; you can redistribute and/or modify it under
 * the terms of the GNU Lesser General Public Licence as published
 * by the Free Software Foundation.
 * See the COPYING file for more information.
 * Author: Sandro Santilli <strk at refractions.net>
#include <geos/geom/Geometry.h>
#include <geos/geom/prep/PreparedGeometry.h>
#include <geos/geom/prep/PreparedGeometryFactory.h>
#include <geos/geom/GeometryCollection.h>
#include <geos/geom/Polygon.h>
#include <geos/geom/Point.h>
#include <geos/geom/MultiPoint.h>
#include <geos/geom/MultiLineString.h>
#include <geos/geom/MultiPolygon.h>
#include <geos/geom/LinearRing.h>
#include <geos/geom/LineString.h>
#include <geos/geom/PrecisionModel.h>
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/CoordinateSequenceFactory.h>
#include <geos/geom/IntersectionMatrix.h>
#include <geos/io/WKTReader.h>
#include <geos/io/WKBReader.h>
#include <geos/io/WKTWriter.h>
#include <geos/io/WKBWriter.h>
#include <geos/io/CLocalizer.h>
#include <geos/simplify/DouglasPeuckerSimplifier.h>
#include <geos/simplify/TopologyPreservingSimplifier.h>
#include <geos/operation/valid/IsValidOp.h>
#include <geos/operation/polygonize/Polygonizer.h>
#include <geos/operation/linemerge/LineMerger.h>
#include <geos/operation/overlay/OverlayOp.h>
#include <geos/geom/BinaryOp.h>
#include <geos/version.h>
// This should go away
#include <cstdio>
#include <cstdlib>
#include <cstring>
#include <fstream>
#include <iostream>
#include <sstream>
#include <string>
//#include <memory>
// Some extra magic to make type declarations in geos_c.h work - for cross-checking of types in header.
#define GEOSGeometry geos::geom::Geometry
#define GEOSPreparedGeometry geos::geom::prep::PreparedGeometry
#define GEOSCoordSequence geos::geom::CoordinateSequence
#define GEOSWKTReader_t geos::io::WKTReader
#define GEOSWKTWriter_t geos::io::WKTWriter
#define GEOSWKBReader_t geos::io::WKBReader
#define GEOSWKBWriter_t geos::io::WKBWriter
#include "geos_c.h"
/// Define this if you want operations triggering Exceptions to
/// be printed (will use the NOTIFY channel - only implemented for GEOSUnion so far)
#undef VERBOSE_EXCEPTIONS
#if defined(_MSC_VER)
#  define GEOS_DLL     __declspec(dllexport)
#else
#  define GEOS_DLL
#endif
// import the most frequently used definitions globally
using geos::geom::Geometry;
using geos::geom::LineString;
using geos::geom::Polygon;
using geos::geom::CoordinateSequence;
using geos::geom::GeometryFactory;
using geos::io::WKTReader;
using geos::io::WKTWriter;
using geos::io::WKBReader;
using geos::io::WKBWriter;
using geos::io::CLocalizer;
using geos::operation::overlay::OverlayOp;
using geos::operation::overlay::overlayOp;
typedef std::auto_ptr<Geometry> GeomAutoPtr;
//## PROTOTYPES #############################################
extern "C" const char GEOS_DLL *GEOSjtsport();
extern "C" char GEOS_DLL *GEOSasText(Geometry *g1);
//## GLOBALS ################################################
// NOTE: SRID will have to be changed after geometry creation
static const GeometryFactory *geomFactory =
	GeometryFactory::getDefaultInstance();
static GEOSMessageHandler NOTICE_MESSAGE;
static GEOSMessageHandler ERROR_MESSAGE;
static int WKBOutputDims = 2;
static int WKBByteOrder = getMachineByteOrder();
**  Over-ride new/delete to allow library users to provide their
**  own memory management via callbacks in GEOS_MALLOC and
**  GEOS_FREE. Used primarily by PostGIS to bring GEOS memory
**  management into the PgSQL palloc/pfree memory pools.
#include <exception> // for std::bad_alloc
#include <new>
static GEOSMemoryAllocator GEOS_MALLOC;
static GEOSMemoryDeallocator GEOS_FREE;
void* operator new (size_t size) throw (std::bad_alloc)
  void *p;
  if(GEOS_MALLOC) {
    printf("geos alloc... ");
    p=GEOS_MALLOC(size);
    printf("done!\n");
  else {
    printf("std alloc... ");
    p=malloc(size);
    printf("done!\n");
  if (p==0) { // did malloc succeed?
    throw std::bad_alloc(); // ANSI/ISO compliant behavior
  return p;
void operator delete (void *p) throw()
  if(GEOS_FREE) {
    printf("geos free... ");
    GEOS_FREE(p);
    printf("done!\n");
  else {
    printf("std free... ");
    free(p);
    printf("done!\n");
extern "C" {
void
initGEOS (GEOSMessageHandler nf, GEOSMessageHandler ef)
	NOTICE_MESSAGE = nf;
	ERROR_MESSAGE = ef;
void
initGEOSMemory (GEOSMemoryAllocator ma, GEOSMemoryDeallocator da)
	GEOS_FREE = da;
	GEOS_MALLOC = ma;
void
finishGEOS ()
	// Nothing to do
	//delete geomFactory;
// relate()-related functions
//  return 0 = false, 1 = true, 2 = error occured
char
GEOSDisjoint(const Geometry *g1, const Geometry *g2)
	try {
		bool result;
		result = g1->disjoint(g2);
		return result;
	catch (const std::exception &e)
		ERROR_MESSAGE("%s", e.what());
		return 2;
	catch (...)
		ERROR_MESSAGE("Unknown exception thrown");
		return 2;
char
GEOSTouches(const Geometry *g1, const Geometry *g2)
	try {
		bool result;
		result =  g1->touches(g2);
		return result;
		return 2;
	catch (...)
		return 2;
char
GEOSIntersects(const Geometry *g1, const Geometry *g2)
	try {
		bool result;
		result = g1->intersects(g2);
		return result;
		return 2;
	catch (...)
		return 2;
char
GEOSCrosses(const Geometry *g1, const Geometry *g2)
	try {
		bool result;
		result = g1->crosses(g2);
		return result;
		return 2;
	catch (...)
		return 2;
char
GEOSWithin(const Geometry *g1, const Geometry *g2)
	try {
		bool result;
		result = g1->within(g2);
		return result;
		return 2;
	catch (...)
		return 2;
// call g1->contains(g2)
// returns 0 = false
//         1 = true
//         2 = error was trapped
char
GEOSContains(const Geometry *g1, const Geometry *g2)
	try {
		bool result;
		result = g1->contains(g2);
		return result;
		return 2;
	catch (...)
		return 2;
char
GEOSOverlaps(const Geometry *g1, const Geometry *g2)
	try {
		bool result;
		result = g1->overlaps(g2);
		return result;
		return 2;
	catch (...)
		return 2;
// low-level relate functions
char
GEOSRelatePattern(const Geometry *g1, const Geometry *g2, const char *pat)
	try {
		bool result;
		std::string s = pat;
		result = g1->relate(g2,s);
		return result;
		return 2;
	catch (...)
		return 2;
char *
GEOSRelate(const Geometry *g1, const Geometry *g2)
	using geos::geom::IntersectionMatrix;
	try {
		IntersectionMatrix *im = g1->relate(g2);
		if (im == NULL)
				return NULL;
        std::string s(im->toString());
		char *result = NULL;
		result = (char*) std::malloc( s.length() + 1);
		std::strcpy(result, s.c_str() );
		delete im;
		return result;
	catch (...)
    return NULL;
// isValid
char
GEOSisValid(const Geometry *g1)
	using geos::operation::valid::IsValidOp;
	using geos::operation::valid::TopologyValidationError;
	IsValidOp ivo(g1);
	bool result;
	try {
		result = ivo.isValid();
		if ( result == 0 )
			TopologyValidationError *err = ivo.getValidationError();
			if ( err ) {
				std::string errmsg = err->toString();
				NOTICE_MESSAGE("%s", errmsg.c_str());
		return result;
		return 2;
	catch (...)
		return 2;
// general purpose
char
GEOSEquals(const Geometry *g1, const Geometry *g2)
	try {
		bool result;
		result = g1->equals(g2);
		return result;
		return 2;
	catch (...)
		return 2;
char
GEOSEqualsExact(const Geometry *g1, const Geometry *g2, double tolerance)
	try {
		bool result;
		result = g1->equalsExact(g2, tolerance);
		return result;
		return 2;
	catch (...)
		return 2;
int
GEOSDistance(const Geometry *g1, const Geometry *g2, double *dist)
	try {
		*dist = g1->distance(g2);
		return 1;
		return 0;
	catch (...)
		return 0;
int
GEOSArea(const Geometry *g, double *area)
	try {
		*area = g->getArea();
		return 1;
		return 0;
	catch (...)
		return 0;
int
GEOSLength(const Geometry *g, double *length)
	try {
		*length = g->getLength();
		return 1;
		return 0;
	catch (...)
		return 0;
Geometry *
GEOSGeomFromWKT(const char *wkt)
    CLocalizer clocale;
	try
		WKTReader r(geomFactory);
		const std::string wktstring = std::string(wkt);
		Geometry *g = r.read(wktstring);
		return g;
		return NULL;
	catch (...)
		return NULL;
char *
GEOSGeomToWKT(const Geometry *g1)
    CLocalizer clocale;
	try
		std::string s = g1->toString();
		char *result;
        return result;
		return NULL;
	catch (...)
		return NULL;
// Remember to free the result!
unsigned char *
GEOSGeomToWKB_buf(const Geometry *g, size_t *size)
	try
		int byteOrder = (int) WKBByteOrder;
		WKBWriter w(WKBOutputDims, byteOrder);
		std::ostringstream s(std::ios_base::binary);
		w.write(*g, s);
		std::string wkbstring = s.str();
		size_t len = wkbstring.length();
		unsigned char *result;
		result = (unsigned char*) std::malloc(len);
        std::memcpy(result, wkbstring.c_str(), len);
		*size = len;
		return result;
		return NULL;
	catch (...)
		return NULL;
Geometry *
GEOSGeomFromWKB_buf(const unsigned char *wkb, size_t size)
	try
		std::string wkbstring = std::string((const char*)wkb, size); // make it binary !
		WKBReader r(*geomFactory);
		std::istringstream s(std::ios_base::binary);
		s.str(wkbstring);
		s.seekg(0, std::ios::beg); // rewind reader pointer
		Geometry *g = r.read(s);
		return g;
		return NULL;
	catch (...)
		return NULL;
/* Read/write wkb hex values.  Returned geometries are
   owned by the caller.*/
unsigned char *
GEOSGeomToHEX_buf(const Geometry *g, size_t *size)
	try
		w.writeHEX(*g, s);
		std::string hexstring = s.str();
		size_t len = hexstring.length();
		char *result;
		result = (char*) std::malloc(len);
        std::memcpy(result, hexstring.c_str(), len);
		*size = len;
		return (unsigned char*) result;
		return NULL;
	catch (...)
		return NULL;
Geometry *
GEOSGeomFromHEX_buf(const unsigned char *hex, size_t size)
	try
		std::string hexstring = std::string((const char*)hex, size);
		s.str(hexstring);
		Geometry *g = r.readHEX(s);
		return g;
		return NULL;
	catch (...)
		return NULL;
char
GEOSisEmpty(const Geometry *g1)
	try
		return g1->isEmpty();
		return 2;
	catch (...)
		return 2;
char
GEOSisSimple(const Geometry *g1)
	try
		return g1->isSimple();
		return 2;
	catch (...)
		return 2;
char
GEOSisRing(const Geometry *g)
	try
		const LineString *ls = dynamic_cast<const LineString *>(g);
		if ( ls ) {
			return (ls->isRing());
		} else {
			return 0;
		return 2;
	catch (...)
		return 2;
//free the result of this
char *
GEOSGeomType(const Geometry *g1)
	try
		std::string s = g1->getGeometryType();
		char *result;
		return result;
		return NULL;
	catch (...)
		return NULL;
// Return postgis geometry type index
int
GEOSGeomTypeId(const Geometry *g1)
	try
		return g1->getGeometryTypeId();
		return -1;
	catch (...)
		return -1;
// GEOS functions that return geometries
Geometry *
GEOSEnvelope(const Geometry *g1)
	try
		Geometry *g3 = g1->getEnvelope();
		return g3;
		return NULL;
	catch (...)
		return NULL;
Geometry *
GEOSIntersection(const Geometry *g1, const Geometry *g2)
	try
		GeomAutoPtr g3 = BinaryOp(g1, g2, overlayOp(OverlayOp::opINTERSECTION));
		return g3.release();
		//Geometry *g3 = g1->intersection(g2);
		//return g3;
		return NULL;
	catch (...)
		return NULL;
Geometry *
GEOSBuffer(const Geometry *g1, double width, int quadrantsegments)
	try
		Geometry *g3 = g1->buffer(width, quadrantsegments);
		return g3;
		return NULL;
	catch (...)
		return NULL;
Geometry *
GEOSConvexHull(const Geometry *g1)
	try
		Geometry *g3 = g1->convexHull();
		return g3;
		return NULL;
	catch (...)
		return NULL;
Geometry *
GEOSDifference(const Geometry *g1, const Geometry *g2)
	try
		GeomAutoPtr g3 = BinaryOp(g1, g2, overlayOp(OverlayOp::opDIFFERENCE));
		//Geometry *g3 = g1->difference(g2);
		//return g3;
		return NULL;
	catch (...)
		return NULL;
Geometry *
GEOSBoundary(const Geometry *g1)
	try
		Geometry *g3 = g1->getBoundary();
		return g3;
		return NULL;
	catch (...)
		return NULL;
Geometry *
GEOSSymDifference(const Geometry *g1, const Geometry *g2)
	try
		GeomAutoPtr g3 = BinaryOp(g1, g2, overlayOp(OverlayOp::opSYMDIFFERENCE));
		//Geometry *g3 = g1->symDifference(g2);
		//return g3;
		return NULL;
	catch (...)
		return NULL;
Geometry *
GEOSUnion(const Geometry *g1, const Geometry *g2)
	try
		GeomAutoPtr g3 = BinaryOp(g1, g2, overlayOp(OverlayOp::opUNION));
		//Geometry *g3 = g1->Union(g2);
		//return g3;
#if VERBOSE_EXCEPTIONS
		std::ostringstream s;
		s << "Exception on GEOSUnion with following inputs:" << std::endl;
		s << "A: "<<g1->toString() << std::endl;
		s << "B: "<<g2->toString() << std::endl;
		NOTICE_MESSAGE("%s", s.str().c_str());
#endif // VERBOSE_EXCEPTIONS
		return NULL;
	catch (...)
		return NULL;
Geometry *
GEOSPointOnSurface(const Geometry *g1)
	try
		Geometry *ret = g1->getInteriorPoint();
		if ( ! ret ) return geomFactory->createGeometryCollection();
		return ret;
		return NULL;
	catch (...)
		return NULL;
// memory management functions
void
GEOSGeom_destroy(Geometry *a)
	try{
		delete a;
	catch (...)
void
GEOSSetSRID(Geometry *g, int SRID)
	g->setSRID(SRID);
void
GEOSdeleteChar(char *a)
	try{
	   free(a);
	catch (...)
int
GEOSGetNumCoordinates(const Geometry *g1)
	try{
		return g1->getNumPoints();
		return -1;
	catch (...)
		return -1;
 * Return -1 on exception, 0 otherwise.
 * Converts Geometry to normal form (or canonical form).
int
GEOSNormalize(Geometry *g1)
	try{
		g1->normalize();
		return -1;
	catch (...)
		return -1;
    return 0;
int
GEOSGetNumInteriorRings(const Geometry *g1)
	try{
		const Polygon *p = dynamic_cast<const Polygon *>(g1);
                if ( ! p )
                        ERROR_MESSAGE("Argument is not a Polygon");
                        return -1;
		return p->getNumInteriorRing();
		return -1;
	catch (...)
		return -1;
// returns -1 on error and 1 for non-multi geometries
int
GEOSGetNumGeometries(const Geometry *g1)
	try{
		return g1->getNumGeometries();
		return -1;
	catch (...)
		return -1;
 * Call only on GEOMETRYCOLLECTION or MULTI*.
 * Return a pointer to the internal Geometry.
const Geometry *
GEOSGetGeometryN(const Geometry *g1, int n)
	using geos::geom::GeometryCollection;
	try{
		const GeometryCollection *gc = dynamic_cast<const GeometryCollection *>(g1);
		if ( ! gc )
			ERROR_MESSAGE("Argument is not a GeometryCollection");
			return NULL;
		return gc->getGeometryN(n);
		return NULL;
	catch (...)
		return NULL;
 * Call only on polygon
 * Return a copy of the internal Geometry.
const Geometry *
GEOSGetExteriorRing(const Geometry *g1)
	try{
		if ( ! p )
			ERROR_MESSAGE("Invalid argument (must be a Polygon)");
			return NULL;
		return p->getExteriorRing();
		return NULL;
	catch (...)
		return NULL;
 * Return a pointer to internal storage, do not destroy it.
const Geometry *
GEOSGetInteriorRingN(const Geometry *g1, int n)
	try{
		if ( ! p )
			return NULL;
		return p->getInteriorRingN(n);
		return NULL;
	catch (...)
		return NULL;
Geometry *
GEOSGetCentroid(const Geometry *g)
	try{
		Geometry *ret = g->getCentroid();
		return ret;
		return NULL;
	catch (...)
		return NULL;
Geometry *
GEOSGeom_createCollection(int type, Geometry **geoms, unsigned int ngeoms)
#ifdef GEOS_DEBUG
	char buf[256];
	sprintf(buf, "PostGIS2GEOS_collection: requested type %d, ngeoms: %d",
			type, ngeoms);
	NOTICE_MESSAGE("%s", buf);// TODO: Can NOTICE_MESSAGE format that directly?
#endif
	try
		Geometry *g;
		std::vector<Geometry *> *vgeoms = new std::vector<Geometry *>(geoms, geoms+ngeoms);
		switch (type)
			case GEOS_GEOMETRYCOLLECTION:
				g = geomFactory->createGeometryCollection(vgeoms);
				break;
			case GEOS_MULTIPOINT:
				g = geomFactory->createMultiPoint(vgeoms);
				break;
			case GEOS_MULTILINESTRING:
				g = geomFactory->createMultiLineString(vgeoms);
				break;
			case GEOS_MULTIPOLYGON:
				g = geomFactory->createMultiPolygon(vgeoms);
				break;
			default:
				ERROR_MESSAGE("Unsupported type request for PostGIS2GEOS_collection");
				g = NULL;
		if (g==NULL) return NULL;
		return g;
		return NULL;
	catch (...)
		return NULL;
Geometry *
GEOSPolygonize(const Geometry * const * g, unsigned int ngeoms)
	using geos::operation::polygonize::Polygonizer;
	unsigned int i;
	Geometry *out = NULL;
	try{
		// Polygonize
		Polygonizer plgnzr;
		for (i=0; i<ngeoms; i++) plgnzr.add(g[i]);
#if GEOS_DEBUG
	NOTICE_MESSAGE("geometry vector added to polygonizer");
#endif
		std::vector<Polygon *>*polys = plgnzr.getPolygons();
#if GEOS_DEBUG
	NOTICE_MESSAGE("output polygons got");
#endif
		// We need a vector of Geometry pointers, not
		// Polygon pointers.
		// STL vector doesn't allow transparent upcast of this
		// nature, so we explicitly convert.
		// (it's just a waste of processor and memory, btw)
                std::vector<Geometry*> *polyvec =
				new std::vector<Geometry *>(polys->size());
		for (i=0; i<polys->size(); i++) (*polyvec)[i] = (*polys)[i];
		delete polys;
		out = geomFactory->createGeometryCollection(polyvec);
		// the above method takes ownership of the passed
		// vector, so we must *not* delete it
		return NULL;
	catch (...)
		return NULL;
	return out;
Geometry *
GEOSPolygonizer_getCutEdges(const Geometry * const * g, unsigned int ngeoms)
	unsigned int i;
	try{
		// Polygonize
		Polygonizer plgnzr;
#if GEOS_DEBUG
#endif
		std::vector<const LineString *>*lines = plgnzr.getCutEdges();
#if GEOS_DEBUG
#endif
    std::vector<Geometry*> *linevec =
				new std::vector<Geometry *>(lines->size());
		for (i=0; i<lines->size(); i++) (*linevec)[i] = (*lines)[i]->clone();
		out = geomFactory->createGeometryCollection(linevec);
		return NULL;
	catch (...)
		return NULL;
	return out;
Geometry *
GEOSLineMerge(const Geometry *g)
		using geos::operation::linemerge::LineMerger;
        unsigned int i;
        try{
                // LineMerge
                LineMerger lmrgr;
                lmrgr.add(g);
                std::vector<LineString *>*lines = lmrgr.getMergedLineStrings();
#if GEOS_DEBUG
        NOTICE_MESSAGE("output lines got");
#endif
                std::vector<Geometry *>*geoms = new std::vector<Geometry *>(lines->size());
                for (i=0; i<lines->size(); i++) (*geoms)[i] = (*lines)[i];
                delete lines;
                out = geomFactory->buildGeometry(geoms);
                //out = geomFactory->createGeometryCollection(geoms);
		return NULL;
	catch (...)
		return NULL;
        return out;
int
GEOSGetSRID(const Geometry *g1)
	try{
		return g1->getSRID();
		return 0;
	catch (...)
		return 0;
const char *
GEOSversion()
	//static string version = GEOS_CAPI_VERSION;
	return GEOS_CAPI_VERSION;
const char *
GEOSjtsport()
	//string version = jtsport();
	//char *res = strdup(version.c_str());
	//return res;
	return GEOS_JTS_PORT;
char
GEOSHasZ(const Geometry *g)
	if ( g->isEmpty() ) return false;
	double az = g->getCoordinate()->z;
	//ERROR_MESSAGE("ZCoord: %g", az);
	return FINITE(az);
int
GEOS_getWKBOutputDims()
    return WKBOutputDims;
int
GEOS_setWKBOutputDims(int newdims)
	if ( newdims < 2 || newdims > 3 )
		ERROR_MESSAGE("WKB output dimensions out of range 2..3");
	int olddims = WKBOutputDims;
	WKBOutputDims = newdims;
	return olddims;
int
GEOS_getWKBByteOrder()
	return WKBByteOrder;
int
GEOS_setWKBByteOrder(int byteOrder)
	int oldByteOrder = WKBByteOrder;
	WKBByteOrder = byteOrder;
	return oldByteOrder;
CoordinateSequence *
GEOSCoordSeq_create(unsigned int size, unsigned int dims)
	try {
		return geomFactory->getCoordinateSequenceFactory()->create(size, dims);
		return NULL;
	catch (...)
		return NULL;
int
GEOSCoordSeq_setOrdinate(CoordinateSequence *s, unsigned int idx,
	unsigned int dim, double val)
	try {
		s->setOrdinate(static_cast<int>(idx),
			static_cast<int>(dim), val);
		return 1;
		return 0;
	catch (...)
		return 0;
int
GEOSCoordSeq_setX(CoordinateSequence *s, unsigned int idx, double val)
	return GEOSCoordSeq_setOrdinate(s, idx, 0, val);
int
GEOSCoordSeq_setY(CoordinateSequence *s, unsigned int idx, double val)
	return GEOSCoordSeq_setOrdinate(s, idx, 1, val);
int
GEOSCoordSeq_setZ(CoordinateSequence *s, unsigned int idx, double val)
	return GEOSCoordSeq_setOrdinate(s, idx, 2, val);
GEOSCoordSeq_clone(const CoordinateSequence *s)
	try { return s->clone(); }
		return NULL;
	catch (...)
		return NULL;
int
GEOSCoordSeq_getOrdinate(const CoordinateSequence *s, unsigned int idx,
	unsigned int dim, double *val)
	try {
		double d = s->getOrdinate(static_cast<int>(idx),
			static_cast<int>(dim));
		*val = d;
		return 1;
		return 0;
	catch (...)
		return 0;
int
GEOSCoordSeq_getX(const CoordinateSequence *s, unsigned int idx, double *val)
	return GEOSCoordSeq_getOrdinate(s, idx, 0, val);
int
GEOSCoordSeq_getY(const CoordinateSequence *s, unsigned int idx, double *val)
	return GEOSCoordSeq_getOrdinate(s, idx, 1, val);
int
GEOSCoordSeq_getZ(const CoordinateSequence *s, unsigned int idx, double *val)
	return GEOSCoordSeq_getOrdinate(s, idx, 2, val);
int
GEOSCoordSeq_getSize(const CoordinateSequence *s, unsigned int *size)
	try {
		int sz = s->getSize();
		*size = static_cast<unsigned int>(sz);
		return 1;
		return 0;
	catch (...)
		return 0;
int
GEOSCoordSeq_getDimensions(const CoordinateSequence *s, unsigned int *dims)
	try {
		unsigned int dm = s->getDimension();
		*dims = dm;
		return 1;
		return 0;
	catch (...)
		return 0;
void
GEOSCoordSeq_destroy(CoordinateSequence *s)
	try{
		delete s;
	catch (...)
GEOSGeom_getCoordSeq(const Geometry *g)
        using geos::geom::Point;
	try
		if ( ls )
			return ls->getCoordinatesRO();
		const Point *p = dynamic_cast<const Point *>(g);
		if ( p )
			return p->getCoordinatesRO();
		ERROR_MESSAGE("Geometry must be a Point or LineString");
		return NULL;
		return NULL;
	catch (...)
		return NULL;
Geometry *
GEOSGeom_createPoint(CoordinateSequence *cs)
	try { return geomFactory->createPoint(cs); }
		return NULL;
	catch (...)
		return NULL;
Geometry *
GEOSGeom_createLinearRing(CoordinateSequence *cs)
	try { return geomFactory->createLinearRing(cs); }
		return NULL;
	catch (...)
		return NULL;
Geometry *
GEOSGeom_createLineString(CoordinateSequence *cs)
	try { return geomFactory->createLineString(cs); }
		return NULL;
	catch (...)
		return NULL;
Geometry *
GEOSGeom_createPolygon(Geometry *shell, Geometry **holes, unsigned int nholes)
        using geos::geom::LinearRing;
	try
		std::vector<Geometry *> *vholes = new std::vector<Geometry *>(holes, holes+nholes);
		LinearRing *nshell = dynamic_cast<LinearRing *>(shell);
		if ( ! nshell )
			ERROR_MESSAGE("Shell is not a LinearRing");
			return NULL;
		return geomFactory->createPolygon(nshell, vholes);
		return NULL;
	catch (...)
		return NULL;
Geometry *
GEOSGeom_clone(const Geometry *g)
	try { return g->clone(); }
		return NULL;
	catch (...)
		return NULL;
int
GEOSGeom_getDimensions(const Geometry *g)
	try {
		if ( ls )
			return ls->getCoordinatesRO()->getDimension();
		if ( p )
			return p->getCoordinatesRO()->getDimension();
		const Polygon *poly = dynamic_cast<const Polygon *>(g);
		if ( poly )
			return GEOSGeom_getDimensions(poly->getExteriorRing());
		const GeometryCollection *coll =
			dynamic_cast<const GeometryCollection *>(g);
		if ( coll )
			if ( coll->isEmpty() ) return 0;
			return GEOSGeom_getDimensions(coll->getGeometryN(0));
		ERROR_MESSAGE("Unknown geometry type");
		return 0;
		return 0;
	catch (...)
		return 0;
Geometry *
GEOSSimplify(const Geometry *g1, double tolerance)
	using namespace geos::simplify;
	try
		Geometry::AutoPtr g(DouglasPeuckerSimplifier::simplify(
				g1, tolerance));
		return g.release();
		return NULL;
	catch (...)
		return NULL;
Geometry *
GEOSTopologyPreserveSimplify(const Geometry *g1, double tolerance)
	try
		Geometry::AutoPtr g(TopologyPreservingSimplifier::simplify(
				g1, tolerance));
		return g.release();
		return NULL;
	catch (...)
		return NULL;
/* WKT Reader */
WKTReader *
GEOSWKTReader_create()
	try
		return new WKTReader(geomFactory);
		return NULL;
	catch (...)
		return NULL;
void
GEOSWKTReader_destroy(WKTReader *reader)
	try
		delete reader;
	catch (...)
Geometry*
GEOSWKTReader_read(WKTReader *reader, const char *wkt)
    CLocalizer clocale;
	try
		Geometry *g = reader->read(wktstring);
		return g;
		return NULL;
	catch (...)
		return NULL;
/* WKT Writer */
WKTWriter *
GEOSWKTWriter_create()
	try
		return new WKTWriter();
		return NULL;
	catch (...)
		return NULL;
void
GEOSWKTWriter_destroy(WKTWriter *Writer)
	try
		delete Writer;
	catch (...)
char*
GEOSWKTWriter_write(WKTWriter *writer, const Geometry *geom)
    CLocalizer clocale;
	try
		std::string s = writer->write(geom);
		return result;
	catch (...)
    return NULL;
/* WKB Reader */
WKBReader *
GEOSWKBReader_create()
	try
		return new WKBReader(*geomFactory);
	catch (...)
    return NULL;
void
GEOSWKBReader_destroy(WKBReader *reader)
	try
		delete reader;
	catch (...)
Geometry*
GEOSWKBReader_read(WKBReader *reader, const unsigned char *wkb, size_t size)
	try
		s.str(wkbstring);
		Geometry *g = reader->read(s);
		return g;
	catch (...)
    return NULL;
Geometry*
GEOSWKBReader_readHEX(WKBReader *reader, const unsigned char *hex, size_t size)
	try
		s.str(hexstring);
		Geometry *g = reader->readHEX(s);
		return g;
	catch (...)
    return NULL;
/* WKB Writer */
WKBWriter *
GEOSWKBWriter_create()
	try
		return new WKBWriter();
	catch (...)
    return NULL;
void
GEOSWKBWriter_destroy(WKBWriter *Writer)
	try
		delete Writer;
	catch (...)
/* The owner owns the result */
unsigned char*
GEOSWKBWriter_write(WKBWriter *writer, const Geometry *geom, size_t *size)
	try
		writer->write(*geom, s);
		unsigned char *result = NULL;
		*size = len;
		return result;
	catch (...)
    return NULL;
unsigned char*
GEOSWKBWriter_writeHEX(WKBWriter *writer, const Geometry *geom, size_t *size)
	try
		writer->writeHEX(*geom, s);
		const size_t len = wkbstring.length();
		*size = len;
		return result;
	catch (...)
    return NULL;
int
GEOSWKBWriter_getOutputDimension(const GEOSWKBWriter* writer)
	try
		return writer->getOutputDimension();
	catch (...)
    return 0;
void
GEOSWKBWriter_setOutputDimension(GEOSWKBWriter* writer, int newDimension)
	try
		return writer->setOutputDimension(newDimension);
	catch (...)
int
GEOSWKBWriter_getByteOrder(const GEOSWKBWriter* writer)
	try
		return writer->getByteOrder();
	catch (...)
    return 0;
void
GEOSWKBWriter_setByteOrder(GEOSWKBWriter* writer, int newByteOrder)
	try
		return writer->setByteOrder(newByteOrder);
	catch (...)
char
GEOSWKBWriter_getIncludeSRID(const GEOSWKBWriter* writer)
	try
		return writer->getIncludeSRID();
	catch (...)
		return NULL;
void
GEOSWKBWriter_setIncludeSRID(GEOSWKBWriter* writer, const char newIncludeSRID)
	try
		writer->setIncludeSRID(newIncludeSRID);
	catch (...)
// Prepared Geometry
const geos::geom::prep::PreparedGeometry*
GEOSPrepare(const Geometry *g)
    const geos::geom::prep::PreparedGeometry* prep = NULL;
    try
		prep = geos::geom::prep::PreparedGeometryFactory::prepare(g);
	catch (...)
    return prep;
void
GEOSPreparedGeom_destroy(geos::geom::prep::PreparedGeometry *a)
	try
		delete a;
	catch (...)
char
GEOSPreparedContains(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
	try
		bool result;
		result = pg1->contains(g2);
		return result;
		return 2;
	catch (...)
		return 2;
char
GEOSPreparedContainsProperly(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
	try
		bool result;
		result = pg1->containsProperly(g2);
		return result;
		return 2;
	catch (...)
		return 2;
char
GEOSPreparedCovers(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
	try
		bool result;
		result = pg1->covers(g2);
		return result;
		return 2;
	catch (...)
		return 2;
char
GEOSPreparedIntersects(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
	try
		bool result;
		result = pg1->intersects(g2);
		return result;
		return 2;
	catch (...)
		return 2;
} //extern "C"
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20080930/ece634c8/geos_c.h-0001.obj
