[geos-devel] Something wrong with GEOSEnvelope function in 3.1.0?
Obe, Regina robe.dnd at cityofboston.gov
Tue Apr 14 23:05:04 EDT 2009
LiN ,
I'm using GEOS 3.1.0 as well.  However on further inspection it looks like PostGIS uses its own implementation of Envelope and not the GEOS one, so you could very well be right that there is something wrong with that GEOS function.
Unfortunately I don't know enough about GEOS to test it apart from PostGIS.
Maybe Mateusz or Sandro or Paul can confirm the issue.
Thanks,
Regina
-----Original Message-----
From: geos-devel-bounces at lists.osgeo.org on behalf of LiN YongHeng
Sent: Tue 4/14/2009 10:35 PM
To: geos-devel at lists.osgeo.org
Subject: [geos-devel] Re: geos-devel Digest, Vol 78, Issue 11
Hi Regina,
        The GEOS' Version I used is "3.1.0". Today, I use
GEOSEnvelop("LINESTRING(1 3,1 6)") again, what a pity, it don't return the
result like what you said. In my program, the result is "POLYGON ((1  3, 1
3, 1  6, 1  6, 1 3))". So I want to ask you which version of GEOS are you
using?
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20090414/7f86ac58/attachment.html
