[geos-devel] [GEOS] #249: GEOS, Shapely, DLLs, and memory
GEOS geos-trac at osgeo.org
Mon Apr 27 16:37:17 EDT 2009
 Reporter:  aronb       |       Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.2.0
Component:  Default     |     Version:  3.1.0
 Severity:  Unassigned  |    Keywords:
 Add a GEOSFree function to the capi so that users can free memory
 allocated in the GEOS DLL from the same DLL. This is needed if the user
 code is using a different copy of the CRT than GEOS.
  * [http://lists.osgeo.org/pipermail/geos-devel/2009-April/004102.html
 Original post to geos-devel]
  * [http://msdn.microsoft.com/en-us/library/ms235460.aspx Potential Errors
 Passing CRT Objects Across DLL Boundaries]
Ticket URL: <http://trac.osgeo.org/geos/ticket/249>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
