[geos-devel] Re: geos-devel Digest, Vol 82, Issue 7
Jo doublebyte at gmail.com
Wed Aug 5 19:13:25 EDT 2009
I'm fighting with some memory leaks at the moment, and I was wondering
what's the best way to release an object created with GeometryFactory; for
instance:
geos::geom::GeometryFactory::createPoint(geos::geom::Coordinate const&)
Is it GeometryFactory::DestroyGeometry ?
Sorry, but I did not see any reference on how to do this on the
documentation or examples; if I missed it, it would be great if you could
point me there...
                          Thanks in advance,
                                                    regards,
        Jo
2009/8/5 <geos-devel-request at lists.osgeo.org>
> Send geos-devel mailing list submissions to
>        geos-devel at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>        http://lists.osgeo.org/mailman/listinfo/geos-devel
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>        geos-devel-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of geos-devel digest..."
> Today's Topics:
>   1. Re: Porting LengthIndexedLine.project? (strk)
>   2. Re: Polygonizer returns inner rings on their own? (Martin Davis)
> Message: 1
> Date: Tue, 4 Aug 2009 20:51:58 +0200
> From: strk <strk at keybit.net>
> Subject: Re: [geos-devel] Porting LengthIndexedLine.project?
> To: David Turner <novalis at novalis.org>, Martin Davis
>        <mbdavis at refractions.net>,      GEOS Development List
>        <geos-devel at lists.osgeo.org>
> Message-ID: <20090804185158.GA30859 at keybit.net>
> Content-Type: text/plain; charset=us-ascii
> Martin forgot to answer publically, anyway, he mentioned
> tests are here: test.jts.junit.linearref
> NOTE: they are only in CVS:
>  :pserver:cvs at cvs.jump-project.org:/home/cvs/jts
> --strk;
>  Free GIS & Flash consultant/developer      ()  ASCII Ribbon Campaign
>  http://foo.keybit.net/~strk/services.html<http://foo.keybit.net/%7Estrk/services.html> /\  Keep it simple!
> On Sun, Aug 02, 2009 at 03:23:18PM +0200, strk wrote:
> > Let's ask Martin...
> > Are unit tests for LengthIndexedLine available or to be made ?
> > --strk;
> > On Sat, Aug 01, 2009 at 12:02:07AM -0400, David Turner wrote:
> > > On Mon, 2009-07-27 at 17:42 -0400, David Turner wrote:
> > > > On Thu, 2009-07-23 at 21:53 +0200, strk wrote:
> > > > > On Thu, Jul 23, 2009 at 11:13:34AM -0400, David Turner wrote:
> > > > > > JTS has a class called LengthIndexedLine with a method "project",
> which
> > > > > > lets you figure out  the nearest point on a line to a given
> point.  This
> > > > > > is useful, for instance, if you are trying to figure out what
> street a
> > > > > > person is on from (possibly slightly inaccurate) GPS
> observations.
> http://tsusiatsoftware.net/jts/javadoc/com/vividsolutions/jts/linearref/LengthIndexedLine.html#project(com.vividsolutions.jts.geom.Coordinate)<http://tsusiatsoftware.net/jts/javadoc/com/vividsolutions/jts/linearref/LengthIndexedLine.html#project%28com.vividsolutions.jts.geom.Coordinate%29>
> > > > > > PostGIS calls this function st_line_locate_point.
> > > > > > GEOS doesn't seem to have it, even though I was under the
> impression
> > > > > > that GEOS was merely a port of JTS.  If I port JTS's project
> function
> > > > > > and related functions such as extractPoint to GEOS, would that
> patch be
> > > > > > likely to be accepted?  Or am I missing something about the
> relationship
> > > > > > between JTS and GEOS?
> > > > > Your patch would be welcome. Make sure to include unit testing
> please.
> > > > I have a patch.  Unfortunately, I do not yet have unit tests, because
> I
> > > > cannot find the relevant Java unit tests to port.  I could write my
> own,
> > > > but it seems like some of the other code uses ported Java unit tests,
> > > > and I want to follow the common practice.
> > > > Can you point me to the Java unit tests?
> > > Just wanted to follow up to be sure this wasn't lost.  The example I'm
> > > looking at, in case I'm missing something, is:
> > > tests/unit/algorithm/RobustLineIntersectionTest.cpp
> > > which claims to be:
> > > Ported from JTS junit/algorithm/RobustLineIntersectionTest.java
> > > I assume there are probably similar tests for the linearref stuff, but
> > > the JTS CVS appears to be empty or down or something, and Googling
> turns
> > > up nothing.
> > > _______________________________________________
> Message: 2
> Date: Wed, 05 Aug 2009 09:01:07 -0700
> From: Martin Davis <mbdavis at refractions.net>
> Subject: Re: [geos-devel] Polygonizer returns inner rings on their
>        own?
> To: GEOS Development List <geos-devel at lists.osgeo.org>
> Message-ID: <4A79ACC3.4050703 at refractions.net>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> The Polygonizer creates every possible polygon defined by the input
> linework.  That is, it forms the linework into a polygonal coverage.
> That's why the hole also has a polygon filling it.
> This is one common requirement for polygonization.  Howwever, I can see
> that it might be useful to be able to specify that the Polygonizer
> should return only a (Multi)Polygon out of the input linework, which
> sounds like it would meet your need.  This would compute the depth
> parity of the (potentially nested) polygons, and discard those with even
> parity.  I might try and add this to JTS shortly.
> Frederik Ramm wrote:
> > Hi,
> >    why is it that the (C++) Polygonizer, when given the following four
> > geometries,
> >         "LINESTRING(1 1, 1 10, 10 10)"
> >         "LINESTRING(10 10, 10 1, 1 1)"
> >         "LINESTRING(20 20, 20 30, 30 30, 30 20, 20 20)"
> >         "LINESTRING(3 3, 3 4, 4 4, 4 3, 3 3)"
> > (1 and 2 together form a shell, 3 forms a disjunct shell, 4 forms an
> > inner ring of 1+2)
> > returns a collection of three polygons:
> > POLYGON ((1.00 1.00, 1.00 10.00, 10.00 10.00, 10.00 1.00, 1.00 1.00),
> > (3.00 3.00, 4.00 3.00, 4.00 4.00, 3.00 4.00, 3.00 3.00))
> > POLYGON ((20.00 20.00, 20.00 30.00, 30.00 30.00, 30.00 20.00, 20.00
> > 20.00))
> > POLYGON ((3.00 3.00, 3.00 4.00, 4.00 4.00, 4.00 3.00, 3.00 3.00))
> > I'm ok with the first and second, but the third one has already been
> > used as a "hole" inside the first and should not be returned again -
> > or is there a misunderstanding on my part?
> > Bye
> > Frederik
> Martin Davis
> Senior Technical Architect
> Refractions Research, Inc.
> (250) 383-3022
> End of geos-devel Digest, Vol 82, Issue 7
"#define QUESTION ((bb) || !(bb))"  (Shakespeare)
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20090806/3511a9ad/attachment-0001.html
