[geos-devel] [GEOS] #285: C api for project and interpolate
GEOS geos-trac at osgeo.org
Mon Aug 17 10:38:34 EDT 2009
 Reporter:  novalis     |       Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  3.0.3
 Severity:  Unassigned  |    Keywords:
 I have created a C api for the two most straightforward linear referencing
 functions.  I made two versions: standard, and normalized.  The normalized
 ones take/return values between 0 and 1 -- this is intended for
 compatibility with postgis's st_line_locate_point / st_line_interpolate.
Ticket URL: <http://trac.osgeo.org/geos/ticket/285>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
