[geos-devel] problemas al ejecutar make de geos
Paul Ramsey pramsey at cleverelephant.ca
Wed Aug 19 14:02:33 EDT 2009
You have not got g++ (the compiler) installed. You'll need to install
a compiler before you can build from source. How you do that is
dependent on what operating system you are running.
P.
On Wed, Aug 19, 2009 at 12:36 PM, Gloria Candia
Cuno<candia234 at hotmail.com> wrote:
> alguien puede ayudarme, mi sistema operativo es ubuntu y al ejecutar make me
> sale este error, por favor responder.
> Making all in
> source
> make[1]: se ingresa al directorio
> `/usr/local/geos-3.0.3/source'
> Making all in
> algorithm
> make[2]: se ingresa al directorio
> `/usr/local/geos-3.0.3/source/algorithm'
> source='CGAlgorithms.cpp' object='CGAlgorithms.lo' libtool=yes
>         DEPDIR=.deps depmode=none /bin/bash ../../depcomp
>         /bin/bash ../../libtool --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H
> -I. -I. -I../../source/headers -I../../source/headers/geos
> -I../../source/headers     -DGEOS_INLINE -Wall -ansi -pedantic
> -Wno-long-long -c -o CGAlgorithms.lo
> CGAlgorithms.cpp
> libtool: ignoring unknown tag
> CXX
>  g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers
> -I../../source/headers/geos -I../../source/headers -DGEOS_INLINE -Wall -ansi
> -pedantic -Wno-long-long -c CGAlgorithms.cpp  -fPIC -DPIC -o
> .libs/CGAlgorithms.o
> env: g++: No such file or
> directory
> make[2]: *** [CGAlgorithms.lo] Error
> 1
> make[2]: se sale del directorio
> make[1]: *** [all-recursive] Error
> 1
> make[1]: se sale del directorio
> make: *** [all-recursive] Error
> 1
> prueba at geoprac:/usr/local/geos-3.0.3$ sudo /etc/init.d/postgresql-8.3
> restart
>  * Restarting PostgreSQL 8.3 database
> server                                             [ OK ]
> prueba at geoprac:/usr/local/geos-3.0.3$ sudo make
> Making all in source
> make[1]: se ingresa al directorio `/usr/local/geos-3.0.3/source'
> Making all in algorithm
> make[2]: se ingresa al directorio `/usr/local/geos-3.0.3/source/algorithm'
> source='CGAlgorithms.cpp' object='CGAlgorithms.lo' libtool=yes \
>         DEPDIR=.deps depmode=none /bin/bash ../../depcomp \
> CGAlgorithms.cpp
> CXX
> directory
> 1
> 1
> 1
> SALUDOS GLORIA CANDIA
> ________________________________
> ¡Que no te pillen atascos ni radares! En MSN te damos toda la información
> sobre el estado de las carretas y te mostramos dónde se encuentran los
> radares de tráfico.
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
