[geos-devel] GEOSIntersection returns the input
Giacomo Piva piva at meeo.it
Tue Aug 25 06:15:38 EDT 2009
Thank you.
Finally I get the intersection by using 2 polygons from linear ring
Jürgen E. Fischer ha scritto:
> Hi Giacomo,
> some comments:
> On Tue, 25. Aug 2009 at 09:03:47 +0200, Giacomo Piva wrote:
>>    coordseq = (GEOSCoordSeq) GEOSCoordSeq_create(5, 2);   //5 points bi-dimensional
>>    area_1 = GEOSGeom_createLinearRing(coordseq);
>>    area_2 = GEOSGeom_createLinearRing(coordseq);
> You need a new coordinate sequence here.  GEOSGeom_createLinearRing takes
> ownership of it.
>>    intersection = GEOSIntersection(area_1, area_2);
> You're intersecting two rings here.   You might want to GEOSGeom_createPolygon
> from the rings and intersect those.
>>    GEOSCoordSeq_destroy(coordseq);
> The coordinate sequence is owner by the linear ring.  So you shouldn't destroy
> it here.
>>    coordseq = (GEOSCoordSeq) GEOSCoordSeq_create(2, 2);   //2 points bi-dimensional
> The (pointer to the) coordinate sequence you allocate here is lost...
>>        coordseq = (GEOSCoordSeq) GEOSGeom_getCoordSeq(geom);
> ...when you overwrite it here.
> hth
> Jürgen
Giacomo
