[geos-devel] [GEOS] #303: geos 3.2.0rc3 compiling under vc 2005 (using vc80 solution)
GEOS geos-trac at osgeo.org
Wed Dec 2 08:47:11 EST 2009
 Reporter:  robe        |       Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.2.0
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
 Okay this time I'm testing on my VC 2005 box.
 geos_xmltester -- completely missing from vc 2005.
 geos_capi and geos_lib give these errors -- so I guess the same issue as
 was with the vc 2008 solution files (vc90)
 Error   1       fatal error C1083: Cannot open source file:
 '..\..\..\source\geom\util\LinearComponentExtracter.cpp': No such file or
 directory c1xx
 Error   2       fatal error C1083: Cannot open source file:
 '..\..\..\source\geom\util\PointExtracter.cpp': No such file or directory
 c1xx
 Error   3       fatal error C1083: Cannot open source file:
 '..\..\..\source\geom\util\PolygonExtracter.cpp': No such file or
 directory c1xx
 Error   4       fatal error C1083: Cannot open source file:
 '..\..\..\source\operation\overlay\FuzzyPointLocator.cpp': No such file or
 directory        c1xx
 Error   5       fatal error C1083: Cannot open source file:
 '..\..\..\source\operation\overlay\OffsetPointGenerator.cpp': No such file
 or directory     c1xx
 Error   6       fatal error C1083: Cannot open source file:
 '..\..\..\source\operation\overlay\OverlayResultValidator.cpp': No such
 file or directory   c1xx
 Error   7       fatal error C1083: Cannot open source file:
 '..\..\..\source\precision\GeometrySnapper.cpp': No such file or directory
 c1xx
 Error   8       fatal error C1083: Cannot open source file:
 '..\..\..\source\precision\LineStringSnapper.cpp': No such file or
 directory        c1xx
 Error   9       fatal error C1083: Cannot open source file:
 '..\..\..\source\util\AssertionFailedException.cpp': No such file or
 directory      c1xx
 Error   10      fatal error C1083: Cannot open source file:
 '..\..\..\source\util\IllegalArgumentException.cpp': No such file or
 directory      c1xx
 Error   11      fatal error C1083: Cannot open source file:
 '..\..\..\source\util\UnsupportedOperationException.cpp': No such file or
 directory c1xx
 Also get these errors -- from geos_unit project
 Error   55      fatal error C1083: Cannot open source file:
 directory c1xx
 Error   56      fatal error C1083: Cannot open source file:
 c1xx
 Error   57      fatal error C1083: Cannot open source file:
 directory c1xx
 Error   261     fatal error C1083: Cannot open source file:
 directory        c1xx
 Error   262     fatal error C1083: Cannot open source file:
 or directory     c1xx
 Error   263     fatal error C1083: Cannot open source file:
 Error   313     fatal error C1083: Cannot open source file:
 c1xx
 Error   314     fatal error C1083: Cannot open source file:
 directory        c1xx
 Error   316     fatal error C1083: Cannot open source file:
 directory      c1xx
 Error   317     fatal error C1083: Cannot open source file:
 directory      c1xx
 Error   318     fatal error C1083: Cannot open source file:
 directory c1xx
 Error   348     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\geom\coordinatearraysequencefactorytest.cpp
 5
 Error   349     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\geom\coordinatearraysequencetest.cpp
 5
 Error   350     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\geom\coordinatelisttest.cpp
 6
 Error   351     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\geom\coordinatetest.cpp 5
 Error   352     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\geom\dimensiontest.cpp  6
 Error   353     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\geom\envelopetest.cpp   6
 Error   354     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\geom\geometryfactorytest.cpp
 6
 Error   355     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\geom\intersectionmatrixtest.cpp
 5
 Error   356     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\geom\linearringtest.cpp 6
 Error   357     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\geom\linesegmenttest.cpp
 5
 Error   358     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\geom\linestringtest.cpp 6
 Error   359     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\geom\locationtest.cpp   6
 Error   360     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\geom\multilinestringtest.cpp
 5
 Error   361     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\geom\multipointtest.cpp 6
 Error   362     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\geom\multipolygontest.cpp
 5
 Error   363     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\geom\pointtest.cpp      5
 Error   364     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\geom\polygontest.cpp    5
 Error   365     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\geom\triangletest.cpp   6
 Error   366     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\geom\geometry\coverstest.cpp
 6
 Error   367     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\geom\geometry\isrectangletest.cpp
 6
 Error   368     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\geom\prep\preparedgeometryfactorytest.cpp
 6
 Error   369     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\noding\segmentnodetest.cpp
 5
 Error   370     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\noding\segmentpointcomparatortest.cpp
 5
 Error   371     fatal error C1083: Cannot open source file:
 '..\..\..\tests\unit\noding\SegmentStringTest.cpp': No such file or
 directory       c1xx
 Error   372     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\io\byteordervaluestest.cpp
 6
 Error   373     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\io\wkbreadertest.cpp    10
 Error   374     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\simplify\douglaspeuckersimplifiertest.cpp
 5
 Error   375     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\simplify\topologypreservingsimplifiertest.cpp
 5
 Error   376     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\algorithm\convexhulltest.cpp
 6
 Error   377     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\algorithm\pointlocatortest.cpp
 6
 Error   378     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\algorithm\cgalgorithms\computeorientationtest.cpp
 6
 Error   379     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\algorithm\cgalgorithms\isccwtest.cpp
 7
 Error   380     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\algorithm\cgalgorithms\ispointinringtest.cpp
 6
 Error   381     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\index\quadtree\doublebitstest.cpp
 5
 Error   382     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\util\uniquecoordinatearrayfiltertest.cpp
 6
 Error   383     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\operation\issimpleoptest.cpp
 6
 Error   384     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\operation\distance\distanceoptest.cpp
 6
 Error   385     fatal error C1083: Cannot open source file:
 '..\..\..\tests\unit\operation\overlay\FuzzyPointLocatorTest.cpp': No such
 Error   386     fatal error C1083: Cannot open source file:
 '..\..\..\tests\unit\operation\overlay\OffsetPointGeneratorTest.cpp': No
 such file or directory     c1xx
 Error   387     fatal error C1083: Cannot open source file:
 '..\..\..\tests\unit\operation\overlay\OverlayResultValidatorTest.cpp': No
 Error   388     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\operation\union\cascadedpolygonuniontest.cpp
 6
 Error   389     fatal error C1083: Cannot open source file:
 '..\..\..\tests\unit\precision\GeometrySnapperTest.cpp': No such file or
 directory  c1xx
 Error   391     fatal error C1083: Cannot open source file:
 '..\..\..\tests\unit\precision\LineStringSnapperTest.cpp': No such file or
 directory        c1xx
 Error   392     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\precision\simplegeometryprecisionreducertest.cpp
 6
 Error   393     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\capi\geoscoordseqtest.cpp
 5
 Error   394     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\capi\geosgeomtowkttest.cpp
 5
 Error   395     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\capi\geospolygonizer_getcutedgestest.cpp
 5
 Error   396     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\capi\geossimplifytest.cpp
 5
 Error   397     fatal error C1083: Cannot open include file: 'tut.hpp': No
 c:\projects\geos\geos-3.2.0rc3vc2005\tests\unit\geos_unit.cpp   8
Ticket URL: <http://trac.osgeo.org/geos/ticket/303>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
