[geos-devel] Re: Return value of GEOSGeom_getDimensions_r
Fri Dec 11 11:33:14 EST 2009
Alex Trofast wrote:
> Hi Frank,
> The reason I said that is because the fact is I get a 3 no matter which
> type I use (Point, Polygon, or Linestring) and looking at the
> implementation of GEOSGeom_getDimensions_r it is returned as this:
> dim = ls->getCoordinatesRO()->getDimension();
> It does not call the Linestring's getDimension it seems. Does this seem
> like the correct interpretation?
Alex,
Looking in the C bindings, I see what you mean.  I think this is an error
in how the bindings were constructed.  Would you mind filing a ticket on it?
Best regards,
