[geos-devel] Re: [GEOS] #222: GEOS 3.0 won't link on ARM-EABI
platform
geos-trac at osgeo.org
Tue Jan 13 02:11:17 EST 2009
#222: GEOS 3.0 won't link on ARM-EABI platform
Reporter: jcrepetto | Owner: geos-devel at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: 3.0.0
Severity: Critical | Resolution:
Keywords: |
Comment (by jcrepetto):
You don't need an ARM system to recreate it. The toolchain mentioned above
is a cross-compiler. You just have to install it on your PC, then use it
to compile GEOS.
Ticket URL: <http://trac.osgeo.org/geos/ticket/222#comment:3>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
