[geos-devel] RE: [postgis-devel] Can't compile Geos 3.1
underOpenSUSE anymore
Paul Ramsey
pramsey at cleverelephant.ca
Tue Jan 13 11:05:41 EST 2009
Doesn't make much sense to me. <cstring> is #include'd, so...?
On Tue, Jan 13, 2009 at 7:54 AM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
> Okay that fixed my OpenSUSE compile problem.
> On MingW, getting a different error now -- but haven't done a complete
> clean blowout so it could be remnants of something else. But just in
> case. Below is what I get under MingW
> -DDLL_EXPORT -DPIC -o .libs/libgeos_c_la-geos_ts_c.o
> geos_ts_c.cpp: In function `char*
> GEOSisValidReason_r(GEOSContextHandle_HS*, const
> geos::geom::Geometry*)':
> geos_ts_c.cpp:587: error: `strdup' was not declared in this scope
> geos_ts_c.cpp:587: warning: unused variable 'strdup'
> GEOSWKBWriter_getIncludeSRID_r(GEOSContextHandle_HS*, const
> GEOSWKBWriter*)':
> geos_ts_c.cpp:3682: warning: converting to non-pointer type `char' from
> NULL
> geos_ts_c.cpp:3688: warning: converting to non-pointer type `char' from
> NULL
> geos_ts_c.cpp:3699: warning: converting to non-pointer type `char' from
> NULL
> make[1]: *** [libgeos_c_la-geos_ts_c.lo] Error 1
> make[1]: Leaving directory `/D/SVNProjects/geos/trunk/capi'
> make: *** [all-recursive] Error 1
> I'll be testing under Visual Studio in the next day or so.
> -----Original Message-----
> From: geos-devel-bounces at lists.osgeo.org
> [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
> Sent: Tuesday, January 13, 2009 10:49 AM
> To: GEOS Development List
> Subject: Re: [geos-devel] RE: [postgis-devel] Can't compile Geos 3.1
> Yep, same here on a fresh checkout. And there was indeed a file
> missing from my check-in. Fixed at r2233.
> P.
> On Tue, Jan 13, 2009 at 7:02 AM, Obe, Regina <robe.dnd at cityofboston.gov>
> wrote:
>> Mark,
>> Good thought. I can't remember if I did an autogen or not, but just
> did
>> and my OpenSUSE is still compiling.
>> My MingW install which I did do an sh autogen.sh , configure, make
>> clean, make is failing with the same error
>> g++ -DHAVE_CONFIG_H -I. -I. -I../source/headers
>> -I../source/headers/geos -I../source/headers
>> -DGEOS_CAPI_VERSION=\"3.1.0-CAPI-1.5.0\" -DGEOS_JTS_PORT=\"1.7.1\" -g
>> -O2 -DGEOS_INLINE -Wall -ansi -pedantic -Wno-long-long -MT
>> libgeos_c_la-geos_c.lo -MD -MP -MF .deps/libgeos_c_la-geos_c.Tpo -c
>> geos_c.cpp -DDLL_EXPORT -DPIC -o .libs/libgeos_c_la-geos_c.o
>> geos_c.cpp -o libgeos_c_la-geos_c.o >/dev/null 2>&1
>> make[1]: *** No rule to make target `geos_ts_c.cpp', needed by
>> `libgeos_c_la-geos_ts_c.lo'. Stop.
>> Have you tried the latest one?
>> My next step is to blow out my geos source and start from scratch.
>> Thanks,
>> Regina
>> From: postgis-devel-bounces at postgis.refractions.net
>> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of
> Mark
>> Cave-Ayland
>> Sent: Tuesday, January 13, 2009 9:45 AM
>> To: PostGIS Development Discussion
>> Subject: Re: [postgis-devel] Can't compile Geos 3.1 under OpenSUSE
>> anymore
>> Obe, Regina wrote:
>>> I assume this is because of the recent changes. I did an svn up and
> a
>>> reconfigure and then compile under OpenSUSE.
>>> I get this error
>>> g++ -DHAVE_CONFIG_H -I. -I../source/headers -I../source/headers/geos
>>> -I../source/headers -DGEOS_CAPI_VERSION=\"3.1.0-CAPI-1.5.0\"
>>> -DGEOS_JTS_PORT=\"1.7.1\" -g -O2 -DGEOS_INLINE -Wall -ansi -pedantic
>>> -Wno-long-long -MT libgeos_c_la-geos_c.lo -MD -MP -MF
>>> .deps/libgeos_c_la-geos_c.Tpo -c geos_c.cpp -o libgeos_c_la-geos_c.o
>>>> /dev/null 2>&1
>>> mv -f .deps/libgeos_c_la-geos_c.Tpo .deps/libgeos_c_la-geos_c.Plo
>>> make[1]: Leaving directory `/projects/geos-3.1.0SVN/capi'
>>> Am I missing something?
>>> Thanks,
>>> Regina
>> Hmmm the "ts" part implies this is something to do with the
> thread-safe
>> API patch. Perhaps you need to re-run autogen.sh so that it picks up
> the
>> new files? Failing that does a brand new checkout work?
>> HTH,
>> Mark.
>> Mark Cave-Ayland
>> Sirius Corporation - The Open Source Experts
>> http://www.siriusit.co.uk
>> T: +44 870 608 0063
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>> The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure
>> pursuant to Massachusetts law. It is intended
>> solely for the addressee. If you received this in error, please
>> contact the sender and delete the material from any computer.
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geos-devel
