[geos-devel] Minimum Bounding Circle
Bruce Rindahl rindahl at lrcwe.com
Tue Jan 13 13:21:20 EST 2009
I am interested in exploring this issue further.  I believe the the
computation of a minimum bounding circle is a requirement in evaluating
congressional districts (Lee- Reference??).  If so then to have this
function available to a program like PostGIS would be a plus.  I would
like to test this module but need some help.  How do I  expose the
module so it is available in PostGIS?
Bruce
Bruce Rindahl wrote:
> I just looked at MinimumDiameter.cpp and the code does the same thing
> as the first part of my code linked by Regina.  This would be nice to
> have except for one thing - it may not work.  It calls
> distancePerpendicular which I couldn't find.  If this finds the point
> furthest from the /extended/ line segment and uses this to compute the
> diameter it is the same method as I used - rotate the geometry so the
> segment is horizontal and compute the bounding box.  I can provide you
> with a geometry where this algorithm fails.  Lee Meilleur can also
> provide a counter example.  Because of this I changed my code to test
> every point pair for the Minimum Diameter.
> Bruce Rindahl
> Martin Davis wrote:
>> Yes, this is computing the same thing as the Minimum Bounding Circle
>> algorithm.  This algorithm appeared in JTS for some reason which is
>> lost in the mists of time.  AFAIK it's never really been used or
>> tested extensively.
>> It probably postdated the initial port of GEOS, and I guess nobody
>> went looking for it until now...
>> Obe, Regina wrote:
>>> I was snooping around the GEOS library and noticed a curious
>>> algorithm class
>>> called MinimumDiameter.  As far as I can tell from scanning the code,
>>> it seems similar in concept to the the Minimum Bounding Circle
>>> plpgsql algorithm that
>>> Bruce posted in November
>>> http://postgis.refractions.net/pipermail/postgis-users/2008-October/021734.html
>>> Just wondering why this is not exposed in the CAPI interface or does
>>> it server an entirely different purpose from what I am thinking.
>>> Thanks,
>>> Regina
>>> *The substance of this message, including any attachments, may be
>>> confidential, legally privileged and/or exempt from disclosure
>>> pursuant to Massachusetts law. It is intended solely for the
>>> addressee. If you received this in error, please contact the sender
>>> and delete the material from any computer. *
>>> * Help make the earth a greener place. If at all possible resist
>>> printing this email and join us in saving paper. *
>>> geos-devel mailing list
>>> geos-devel at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geos-devel
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20090113/7dafc3e1/attachment.html
