[geos-devel] 3.1.0rc1
Paul Ramsey pramsey at opengeo.org
Thu Jan 29 15:21:46 EST 2009
My database agrees with you, that those are the offending locations:
aggtest=# select gid,name from tm_world_2 where st_dwithin(the_geom,
st_setsrid('POINT(32.4122
 gid |    name
 122 | Mozambique
 224 | Zimbabwe
(2 rows)
But, the union throws no exception:
aggtest=# select a.name, b.name, st_geometrytype(st_union(a.the_geom,
b.the_geom)) from tm_world_2 a, tm_world_2 b where a.gid = 122
    name    |   name   | st_geometrytype
 Mozambique | Zimbabwe | ST_MultiPolygon
(1 row)
On Thu, Jan 29, 2009 at 12:18 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
> I can do an individual union of Mozambique and Zimbabwe without
> problems. Should I be seeing a topology exception?
> P
> On Thu, Jan 29, 2009 at 12:09 PM, Martin Davis <mbdavis at refractions.net> wrote:
>> When I look at the area of the reported TopologyException in OpenJUMP, I'm
>> seeing the following kinds of vertex values:
>> Feature ID: 122
>> [   3:0:666] POINT (32.476230999999984 -21.321853999999973)
>> Feature ID: 222
>> [     0:144] POINT (32.476231 -21.321854)
>> So the dataset is not actually 100% cleanly noded.  These kinds of small
>> discrepancies are exactly the kind of situation which used to cause
>> robustness errors in JTS.  This has pretty much been fixed by the addition
>> of the Geometry Snapping concept.  I think this made it into GEOS - but
>> perhaps there's a bug in it?
>> It should be possible to narrow down the problem by finding the two
>> geometries which containing the problematic points and just working with
>> them.  (Mozambique and Zimbabwe)
>> Paul Ramsey wrote:
>>> Incidentally, the problem is not the invalid geometries. I first tried
>>> the union after "fixing" them with buffer(0), but I just now tried the
>>> union after deleting them, with the same result.
>>> aggtest=# delete from tm_world_2 where not st_isvalid(the_geom);
>>> NOTICE:  Ring Self-intersection at or near point -53.7564 48.5033
>>> NOTICE:  Ring Self-intersection at or near point -70.9172 -54.7086
>>> NOTICE:  Ring Self-intersection at or near point 5.33694 61.5928
>>> NOTICE:  Ring Self-intersection at or near point 143.662 49.3122
>>> DELETE 4
>>> aggtest=# select geometrytype(st_union(the_geom)) from tm_world_2;
>>> NOTICE:  TopologyException: found non-noded intersection between
>>> 32.4122 -21.2178, 32.4762 -21.3219 and 32.4762 -21.3219, 32.4122
>>> -21.2178 32.4756 -21.3208
>>> ERROR:  GEOS2POSTGIS returned an error
>>> aggtest=#
>>> P
>>> On Wed, Jan 28, 2009 at 1:49 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
>>>> For anyone that needs a test geometry, here's Dane's input as a single
>>>> multipolygon:
>>>> http://cleverelephant.dyndns.org/~pramsey/bigmulti.txt.bz2
>>>> On Wed, Jan 28, 2009 at 7:44 AM, Hartmut Kaiser
>>>> <hartmut.kaiser at gmail.com> wrote:
>>>>>> I just did a bit further testing of the new cascaded union goodness
>>>>>> via Shapely. See the linked email below:
>>>>>> http://lists.gispython.org/pipermail/community/2009-January/001960.html
>>>>>> Seems that I reached where a point that 'should never be reached' ?
>>>>>> http://trac.osgeo.org/geos/browser/trunk/source/index/strtree/AbstractS
>>>>>> TRtree.cpp#L358
>>>>>> I am new to looking at the geos code, so any pointers to help me test
>>>>>> more would be great.
>>>>> Could you provide a minimal test I could use to reproduce this problem?
>>>>> Regards Hartmut
>>>>>> Thanks!
>>>>>> Dane
>>>>>> On Jan 27, 2009, at 9:02 PM, Dane Springmeyer wrote:
>>>>>>> Paul,
>>>>>>> I tested on mac 10.5 and ubuntu 8.10 and all configure;make and make
>>>>>>> installs went perfectly.
>>>>>>> Just a few compiler warnings that I've pasted here:
>>>>>> http://dpaste.com/hold/113736/
>>>>>>> Dane
>>>>>>> On Jan 27, 2009, at 10:35 AM, Paul Ramsey wrote:
>>>>>>>> This is a pre-warning to PSC members to download and test the first
>>>>>>>> 3.1 rc tarball:
>>>>>>>> http://download.osgeo.org/geos/geos-3.1.0rc1.tar.bz2
>>>>>>>> If I don't hear any howls of dismay over the next 24 hours, I will
>>>>>>>> make a wider announcement for testing.
>>>>>>>> Paul
>>>>>>>> _______________________________________________
>>>>>>>> geos-devel mailing list
>>>>>>>> geos-devel at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geos-devel
>> Martin Davis
>> Senior Technical Architect
>> Refractions Research, Inc.
>> (250) 383-3022
