[geos-devel] Re: [GEOS] #276: "make check" failed at geos_unit on mingw
GEOS geos-trac at osgeo.org
Tue Jul 14 08:07:48 EDT 2009
 Reporter:  sanak       |        Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |       Status:  new
 Priority:  major       |    Milestone:  3.2.0
Component:  Default     |      Version:  svn-trunk
 Severity:  Unassigned  |   Resolution:
 Keywords:  mingw       |
Comment (by sanak):
 pramsey,
 > You could compile the whole suite w/o optimization
 I had build whole suite without optimization(./configure CXXFLAGS="-g" &&
 make && make check), but XMLTester crushed at heisenbugs.xml and stmlf-
 cases-20070119.xml this time.
 > or just not compile w/ 'check'.
 The compilation seems to be no problem, because geos_unit.exe was created.
 The crush occurred when shell script(tests/unit/testrunner) execute
 geos_unit(.exe).
 > Do you have a patch?
 Yes, please see the attached file(geos_unit-mingw.patch).
 Regards,
Ticket URL: <http://trac.osgeo.org/geos/ticket/276#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
