[geos-devel] [GEOS] #259: IsValidOp unit test<1> failed on windows msvc2008 build environment
GEOS geos-trac at osgeo.org
Sat Jun 6 15:47:39 EDT 2009
 Reporter:  sanak       |       Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.2.0
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
 FINITE(DoubleNotANumber) doesn't return 0 at IsValidOp::isValid.
 I had make patch for this problem.
 the fixed points are as follows.[[BR]]
 1) change DoubleNotANumber value from 1.7e-308 to
 numeric_limits<double>::quiet_NaN().[[BR]]
 1) change DoubleInfinity value from 1.7e+308 to
 numeric_limits<double>::infinity().[[BR]]
 2) add DoubleMax definition (use numeric_limits<double>::max()), because
 JTS Double.MAX_VALUE and Double.POSITIVE_INFINITY are same in GEOS (I
 think that this is a bug).[[BR]]
 3) add Coordinate::isNull for get equality of NaN value.[[BR]]
 I think that xnix environment have same problem (platform.h.in).
 Regards,
Ticket URL: <http://trac.osgeo.org/geos/ticket/259>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
