[geos-devel] 3.1.1rc1 fail under VC 2005 Nmake + SVN pass
Obe, Regina robe.dnd at cityofboston.gov
Mon Jun 15 08:12:56 EDT 2009
We have similar issues with compiling under nmake.
I can successfully compile with nmake VC 2005 the svn branches/3.1
but the tar ball is a no go
its missing nmake.opt
among other things --
This is just my own ineptness, but not sure how to do a make check on an
nmake built one.
If I use the nmaked dlls in PostGIS -- it hmm reads the wrong version
number --
still registers as GEOS="3.1.0-CAPI-1.5.0" (or has branch svn not been
updated?)
Though the one compiled with MingW correctly reads (this one was
compiled from the tar ball)
3.1.1-CAPI-1.6.0
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
