[geos-devel] [GEOS] #234: Intersection Crashes On Multipolygons With Empty Holes
GEOS geos-trac at osgeo.org
Tue Mar 3 11:06:11 EST 2009
 Reporter:  slambright  |       Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.1.0
Component:  Default     |     Version:  3.0.3
 Severity:  Unassigned  |    Keywords:
 When doing operations to complicated multipolygons, I ran across this.
 When I had a multipolygon of the form:
 MULTIPOLYGON (((1.0000000000000000 1.0000000000000000, 1.0000000000000000
 5.0000000000000000, 5.0000000000000000 5.0000000000000000,
 5.0000000000000000 1.0000000000000000, 1.0000000000000000
 1.0000000000000000), EMPTY))
 (empty, but existing, holes polygon)
 and I tried to intersect it with another polygon, say
 MULTIPOLYGON (((3.0000000000000000 3.0000000000000000, 3.0000000000000000
 4.0000000000000000, 4.0000000000000000 4.0000000000000000,
 4.0000000000000000 3.0000000000000000, 3.0000000000000000
 3.0000000000000000)))
 I get the error:
 CoordinateArraySequence.cpp:105: virtual const geos::geom::Coordinate&
 geos::geom::CoordinateArraySequence::getAt(size_t) const: Assertion
 `pos<vect->size()' failed.
 Abort
 However, if there isn't an empty hole polygon it works fine.
 This happens in both geos3.0.0 and geos3.1.0rc2. I'm running SUSE LINUX
 10.1 (X86-64).
Ticket URL: <http://trac.osgeo.org/geos/ticket/234>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
