[geos-devel] Re: [GEOS] #222: GEOS 3.0 won't link on ARM-EABI platform
GEOS geos-trac at osgeo.org
Wed Mar 11 07:10:20 EDT 2009
 Reporter:  jcrepetto  |        Owner:  geos-devel at lists.osgeo.org
     Type:  defect     |       Status:  new
 Priority:  major      |    Milestone:
Component:  Default    |      Version:  3.0.0
 Severity:  Critical   |   Resolution:
 Keywords:             |
Comment (by mloskot):
 I *suppose* it's directly related to a-little-non-standard
 ARM EABI optimization. Here is the problem described in details, with GCC
 4.2.x:
 [http://gcc.gnu.org/ml/gcc-patches/2004-08/msg02645.html C++ PATCH: Key
 methods for ARM EABI]
 See [http://gcc.gnu.org/bugzilla/show_bug.cgi?id=25908#c20 comment 20 from
 Andrew Pinski] for the [http://gcc.gnu.org/bugzilla/show_bug.cgi?id=25908
 GCC Bug 25908]
 I'd suggest to check if this is the same problem you're dealing with. I
 guess it is, and I'm afraid GEOS has nothing to do with it.
 BTW, it's not been planned to be fixed for milestone [milestone:3.1.0]
Ticket URL: <http://trac.osgeo.org/geos/ticket/222#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
