[geos-devel] Re: [GEOS] #238: Internal error: 7 ERROR: GEOS union() threw an error!
GEOS geos-trac at osgeo.org
Fri Mar 13 17:28:09 EDT 2009
 Reporter:  julich      |        Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |       Status:  new
 Priority:  major       |    Milestone:  3.1.0
Component:  Default     |      Version:  3.0.3
 Severity:  Unassigned  |   Resolution:
 Keywords:              |
Comment (by mloskot):
 julich,
 Martin [http://lists.osgeo.org/pipermail/geos-devel/2009-March/003980.html
 has found] that some of your geometries are invalid, are non-simple. I'd
 suggest you to validate '''all''' your geometries if they are correct in
 terms of the [http://www.opengeospatial.org/standards/sfs OGC Simple
 Feature Specification]. If you can confirm they are, then there is a bug
 in GEOS, otherwise this is a false alarm and the ticket is to be closed as
 ''invalid''.
Ticket URL: <http://trac.osgeo.org/geos/ticket/238#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
