[geos-devel] Bug in GEOSEquals predicate ?
Pascal Leroux pa.leroux at gmail.com
Tue Mar 17 01:43:25 EDT 2009
Hi martin,
I had got no particular example.
But, if I have to find intersections and get a geometry collection, I'll
keep your approach in mind and only look at the right (0, 1 or 2D)
components of a geometry collection. In my case, I was only interested in 2D
parts (wrong intersections between buildings/polygons I have to fix).
Thanks
2009/3/16 Martin Davis <mbdavis at refractions.net>
> Yep, that's what you'd have to do.
> Probably a better way to think of this is that you need to decide what
> dimension of geometry you are interested in out of the intersection
> operation.  Then you retain only those components of the result.  In this
> case, since you are checking whether the intersection is equal to one of the
> input polygons, you should retain only the 2D components of the intersection
> result.
> I realize that it would be nice to have it a bit simpler to get the desired
> dimension components from an intersection result.  One idea is to ensure
> that a result GEOMETRYCOLLECTION contains at most 3 (possible multi)
> geometry components, one each for the 0-D, 1-D, and 2-D components.
> In general if you are testing spatial relationships you should try and use
> just predicates.  This will be faster and more accurate.  What are the other
> cases which you think will not be as simple?
> Pascal Leroux wrote:
>> Does it mean that, when I get a geometry collection, the very first thing
>> I have to do is to split it into simple/multiple but homogeneous geometries
>> to go on ?
>> In the script I've posted, I could have use "contains" or "within" with
>> the two polygons instead of "equals" with the intersection, but in others
>> cases, I'm afraid it is not so easy/simple !
>> Can you give me an advice ?
>> Pascal
>> 2009/3/16 Sean Gillies <sgillies at frii.com <mailto:sgillies at frii.com>>
>>    The GEOS C API returns a integer value of 2 to indicate an error.
>>    It's good to learn that geometry collection predicates aren't
>>    supported.
>>    On Mar 16, 2009, at 9:46 AM, Martin Davis wrote:
>>        GEOS does not support evaluating predicates on
>>        GEOMETRYCOLLECTIONS (due to the potential complexity and lack
>>        of obvious semantics of heterogeneous collections).
>>        In JTS trying to do this throws an exception.  I'm not sure
>>        how GEOS reacts - or possibly shapely is not handling this
>>        gracefully?
>>            Hi all
>>            while searching for intersections between polygons
>>            (buildings), I have found shapes that make "equals"
>>            predicate crash. With simpler shapes, it occurs too :
>>            >>> from shapely.geometry import Polygon
>>            >>> p1 =
>>            Polygon(((0,0),(0,10),(10,10),(10,0),(8,0),(8,8),(2,8),(2,0)))
>>            >>> p2 = Polygon(((2,0),(2,8),(8,8),(7,4),(8,0)))
>>            >>> inter = p1.intersection(p2)
>>            >>> inter.is_valid and p1.is_valid and p2.is_valid
>>            True
>>            >>> inter.wkt
>>            'GEOMETRYCOLLECTION (POINT (8.0000000000000000
>>            0.0000000000000000), LINESTRING (8.0000000000000000
>>            8.0000000000000000, 2.0000000000000000
>>            8.0000000000000000), LINESTRING (2.0000000000000000
>>            8.0000000000000000, 2.0000000000000000 0.0000000000000000))'
>>            >>> inter.equals(p1)
>>            False
>>            >>> inter.equals(p2)
>>            Traceback (most recent call last):
>>             File "<stdin>", line 1, in <module>
>>             File
>>  "/usr/lib/python2.5/site-packages/Shapely-1.0.11-py2.5.egg/shapely/predicates.py",
>>            line 34, in __call__
>>              return bool(self.fn(self.context._geom, other._geom))
>>             File
>>            line 21, in errcheck
>>              raise PredicateError, "Failed to evaluate %s" %
>>            repr(self.fn)
>>            shapely.geos.PredicateError: Failed to evaluate <_FuncPtr
>>            object at 0x96a3bf4>
>>            I have got a Bus Error on MacOSX (libgeos version 3.0.0)
>>            and a Segmentation Fault on Ubuntu (libgeos version 3.0.3)
>>            with an equivalent code written in C (so I think Shapely
>>            is not involved).
>>            Any idea ? Did I miss something ?
>>            Pascal
>>            _______________________________________________
>>            geos-devel mailing list
>>            geos-devel at lists.osgeo.org <mailto:geos-devel at lists.osgeo.org>
>>            http://lists.osgeo.org/mailman/listinfo/geos-devel
>>        --        Martin Davis
>>        Senior Technical Architect
>>        Refractions Research, Inc.
>>        (250) 383-3022
> Martin Davis
> (250) 383-3022
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20090317/5033209b/attachment-0001.html
